| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
I have got this marantz CD-53 mk. When I have not used it for many hours, and I turn it on it won't play tracks on the first 30-40 minutes of a CD. Or it might not recognize the CD sometimes. When I start to play the first track it will skip heavily and after a few seconds it stops. When I leave it on for like 20-30 minutes it will play almost flawlessly from the first track. Today I opened it up and pressed slightly on the plastic part marked with the arrow (very slightly) and it played flawlessly from the first track. When I pulled my finger off the plastic part of the transport it started skipping heavily again. When some weight was on this part it played. Even when I had not warmed the player up for 20-30 minutes. http://img460.imageshack.us/my.php?i...mgp1385qh2.jpg and here is the transport from the underside in case this helps http://img374.imageshack.us/my.php?i...mgp1386oz3.jpg Has anyone seen such behaviour before? Can you speculate what this could be due to and how to fix?? By the way i had this SONY scd-xb770qs SACD player and it played redbook MUCH better than this marantz CDP. Will this player get a lot more decent with a few mods? Thanks a lot!! |
#2 | |
Magneto the Gravity Man
To answer the last part of your question first....... YES !!!!! see the huge CD63/73 thread for ideas. Some simple mods give excellent results eg improve the power supply, new clock with its own supply, replace opamps, remove muting and headphone circuits etc. As for your other problem, it sounds as if the mechanism is not correctly set up. It is simple to remove from the cdp. Clean all traces of grease and oil from the gears and sliders. It hardens with age and stops the mech. from working. Andy
If it ain't broke, break it !! Then fix it again. It's called DIY ! |
#3 |
...seems like either a bad contact (old solder joint or some connector loosening up) or bad lubrification/dirt in the mechanic parts.
If it's worse on the first tracks of the disk, it's more likely to be mechanic: when the head moves away from the "blocked" part it works better. Or when warmed up it "lubricates" again. _ |
#4 |
...and you can pick up a new mechanism for about €30.
The original is called a CDM12.1 but you won't find one of those. There's a newer replacement called a VAM1202 which is backwards compatible. I've installed these in two CD-63s and a CD-67SE. ...but try following Andy's advice first. |
#5 |
The cd spin motor is worn out (bearing of the shaft).
Lubricate and the problem will reduce. U have to replace the motor. Gajanan Phadte |
#6 |
Thank you for the replies.
If the problem is mechanical, why would it stop existing when the cdp is on power for like 20-30 minutes? I will try the lubrication process, since the player screeches when i get the tray in and out and I also hear noise when the CD plays and skips. When it doesnt skip I dont get much noise. |
#7 |
If the unit is old enough and/or been heating up in use for long (all relative terms), then it can have a dry solder problem. The symtoms show signs for both the possibilities, mechanical and loose contact due to dry solder.
Gajanan Phadte |
| Marantz CD-16; need belts for transport! | Cobra2 | Digital Source | 6 | 25th June 2010 05:09 PM |
| What Transport in Marantz CD-5003 *** New Launch *** | arupg | Digital Source | 1 | 30th September 2008 07:05 PM |
| Cold start problems with CD transport | Sheldon | Digital Source | 24 | 7th November 2005 11:26 PM |
| Transport screws....Marantz CD40 | Lyra | Digital Source | 1 | 5th February 2004 07:50 PM |
| Audio Alchemy CD transport problems | Russell Sit | Digital Source | 12 | 29th April 2003 08:48 AM |
