Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Laszlo's Valve Output Stage with Lundahl transformer
Old 2nd October 2010, 04:05 PM   #21
stelios is offline stelios
Originally Posted by oshifis View Post
.. AC current is transformed down to 88.4 uA RMS. I measured about 64 mV on the secondary. From these two values one can calculate the load represented by the cathode input impedance. It gives 724 ohms. Since I connected 1.5 k parallel with the cathodes, the true cathode input impedance is 1.4 kohm.
err... how can this be : 724 Ohms || 1.5k Ohms = 1.4k Ohms ?
In my books it is: 496 Ohms.
Am I missing sth ?
cheers
Stelios
Old 4th October 2010, 01:12 PM   #22
lcsaszar is offline lcsaszar  Hungary
Well, I think I was ambiguous. The input impedance of a SRPP cathode (upper or lower) alone would be 1.4k each, the resulting input impedance including the parallel load resistor is 724 ohms.
Laszlo's Valve Output Stage with Lundahl transformerHide this!Advertise here!
DIY valve output stage for PS1 (newbie) graeme uk Digital Line Level 2 2nd December 2008 03:06 PM
3C24 in a SE output stage - output transformer impedance recommendation !!! aldovan Tubes / Valves 15 6th September 2008 11:18 AM
Thorsten's Valve Output Stage with TDA1541DAC juancho Digital Source 73 29th April 2007 02:28 PM
Adding secondary of output transformer into cathodes of output stage ? Eico ST-70 freddymac406 Tubes / Valves 3 21st April 2007 07:15 PM
