Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 15th April 2007, 07:57 PM   #1
387cbrb is offline 387cbrb  Spain
Default Double shunt reg PS
hi gang!
i'm new here so be nice!
i'm trying to design a good PS for TDA1541A
i'm a bit unsure of the use of series regs when audio
currents are involved. is there any way around the
standard LM317(337) -> TL431 combo?
how about a double shunt reg TL431->TL431?
i attach a pic of what i have in mind.
feel free to laugh at it
(sorry for the quality...)
cheers!
Old 15th April 2007, 11:22 PM   #2
Default TL431 operating point
i forgot to ask: is there any optimal operating current for TL431 or anything 1-100mA woul do equally well? datasheets quote data at 10mA...
cheers!
Old 16th April 2007, 10:29 PM   #3
Have you thought about using a capacitance multiplier ?
Could you post a higher quality scan ?
Jon
Old 18th April 2007, 10:46 PM   #4
Default better res. schematics
i attach a better resolution schematics of what i have in mind.
any comments/criticism?
John, i wanted to avoid active elements in series with
the supply rail. perhaps it's not a good idea when digital
currents are involved? i'm new to digital, hence seeking
advice
i rather thought of putting a transistor on top of tl431.
cheers!
Old 20th April 2007, 10:24 PM   #5
Why do you want to avoid active elements in the supply line, just curious ? In which case you wouldn't consider feeding the shunts with a constant current source ?
Jon
Old 21st April 2007, 03:06 PM   #6
hi!
the reason is very simple -- i don't want the audio signal to go through the active elements. in tube world, where i come from, it's a well established fact that shunt tube reg's sound better than series tube reg's. current source behind a shunt is a bit different story and i will try it also.
but my question remains open: since shunts (discrete or integrated) are acknowledged as being superior to series regs, why not pre-regulating with a shunt too and getting rid of a series reg at all? perhaps it simply doesn't matter as a good shunt screens the regs behind? any ideas?
cheers!
Old 21st April 2007, 07:16 PM   #7
Please forgive my ignorance here (I'm learning) but a shunt regulator draws a constant current from the supply - what the load doesn't draw is dumped into the ground therefore the pre-shunt regulator doesn't actually have to 'regulate' anything as it simply supplies a constant DC voltage to the shunt regulator ? So, you want to feed the shunt regulator with something that supplies a clean DC and filters out AC noise ? You could use another (pre) shunt regulator but that will simply dump more current into the ground plus it also has a relatively wide bandwidth so will also couple noise into the second regulator ?
Jon
Old 21st April 2007, 07:29 PM   #8
cheers!
As they are in parallel with each other there would have to be a current source or a dropping resistor between them so that they are at different voltages.
Old 22nd April 2007, 04:58 PM   #9
Art is offline Art
Hi 387cbrb,
I replaced series R in normal TL431 circuit by LM317 in CCS mode. I observed a bit better sound in my non-OS TDA1541A and AD1865 DAC. I think about power J-Fet CCS too. I'll try it soon. Hope this benefit to you too. Any comment are welcome.
Art.
Old 24th March 2008, 03:17 PM   #10
isdom is offline isdom  Australia
Default Greetings from aust.
hi sorry to change the subject but is it ok if you send me a pdf copy of that marantz cd46 manual / schematic, cheers.
my email is
removed by moderators
kind regards dom
Simple Super Shunt and Simple Super Shunt w/CCS vs. JSR03/05 (and other series regs) hollowman Power Supplies 44 7th October 2009 07:01 AM
Double rail PSU, double ground rail connexion ? youyoung21147 Chip Amps 5 6th November 2005 05:12 PM
Shunt volume controll (scaling the shunt resistors) Freddie Solid State 7 30th August 2001 09:47 PM
Page generated in 0.13554 seconds (82.07% PHP - 17.93% MySQL) with 11 queries
