Go Back   Home > Forums > Source & Line > Digital Line Level
Old 12th January 2009, 12:41 AM   #21
Gabdx1 is offline Gabdx1  Canada
Ok, what is sure is that this is proly better than what i/v i had in mind...
I saw also there is this ultimate dac ? based on the same schematics... very interesting...
Old 13th January 2009, 10:29 AM   #22
oshifis is offline oshifis  Hungary
Originally posted by revintage
Hi Oshifis,
To check I have understood this right: About 1541, 25/2=12,5ohm is the highest allowable resistor? Output with 6 ohm will be 6*2=12mV?
A parentesis: About the CD 2V out std I find this unnecessary as not even a poweramp needs this much. Wouldn´t 0dBu=0,775V be enough? Or why not the semiprostd 300mV/10k? If we go for 6ohm load and 0,5V out we then only need 40x gain.
The output current is actually 0 to 4mA, i.e. DC shifted. So the highest allowable resistor is 25/4=6.25ohm.
The resulting voltage drop is 0 to 25mV, that is 12.5mV peak (8.84mV RMS) sitting on 12.5mV DC.
In order to get 2V RMS (2.83V peak) from 8.84mV RMS (12.5mV peak), one needs about 226x gain. Of course, for 0.775V you need 88x, and for 300mV you need only 34x voltage gain.
The DC component must be blocked or shifted.
What I am not sure about, how hard is the +/-25mV compliance limit. How does the distortion increase when it is exceeded? Is there a diode to the substrate inside, a base-emitter diode or what? Is the output current modulated somehow by the output voltage? Questions, that maybe the designers of the chip are able to answer. Or perhaps someone who has measured the distortion vs. load resistor characteristics.
Old 13th January 2009, 12:18 PM   #23
ccschua is offline ccschua  Malaysia
So Can I borrrow the thread.
I am currently running a diy tda1541 with input isolation transformer using DV709.
The output IV is using 4xNE5534 and the DC block by 10uF WIMA MKP4.
I wonder will the discrte output such as OPA Sun V2 / HDAM will improve the sound further.
Old 13th January 2009, 12:23 PM   #24
Old 13th January 2009, 02:32 PM   #25
Try replace 4ne by 4 x AD8599, Best op amp so far....
If you still want more you can check regulator/clock/output caps to like 22 uf and bypass...
If you still want more then discrete opamp/tube
There is no limit to what you can spend !!!!
Ok, seriously if you have a tda1541 made in 1987 it is worth it because they are as good as the new tda1541as2, just maybe a little wilder
Old 27th February 2011, 01:30 PM   #26
Does Philips mention 25mV limit for the passive conversion in 1541? I am aware of such remark in the documentation of 1541A. Having said this, the question is whether I should lower my passive I/U resistor which is now 100Ohm. I know that people suggest something like 30Ohm, but I am not sure whether they refer to 1541 or 1541A.
FS: TDA1541, TDA1543, PCM1704, other digital audio parts OliverD Swap Meet 6 19th December 2007 06:41 PM
DAC: TDA1541 and TDA1543 question morpheus82 Digital Source 44 17th August 2006 12:37 AM
Questions on TDA1543 & TDA1541 mrstone Digital Source 6 22nd December 2003 02:57 PM
TDA1541 / TDA1543 group buy OliverD Parts 3 17th June 2003 06:36 AM
Tda1545 Tda1543 Tda1541 maartentje Digital Line Level 2 10th October 2002 08:50 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
