Chinese DAC in a Box: CS8416 / CS4397
Old 27th December 2006, 08:53 AM   #11
Fin is offline Fin
Fin's Avatar
Just as well Audio Alchemy no longer exists. Don't think they would be too happy about the similarity in the name of the product.
Fin
Old 27th December 2006, 11:37 AM   #12
Foxx510 is offline Foxx510  Australia
I ordered one today too, could be a nice budget upgrade, that DAC chip is supposedly quite nice.
Old 27th December 2006, 01:53 PM   #13
Franz G is offline Franz G  Switzerland
Franz G's Avatar
Modifications step 1:
Separate regulated voltages for digital (8VDC) and audiopart (12VDC).
Goals:
1. Better resistance to mobile phones, flashlights and so on.
2. Less heat on the AMS1117 regulator, the whole board and caps.
3. Improve the sound...
What I did:
1. Broken powerline nearby AMS1117
2. Removed 1N4007 diode and replaced by a ferrite bead.
3. Attached 12VDC (regulated) at the original points.
4. Added a 22uF tantalum for the 8VDC in.
5. Attached 8VDC (regulated) at the new cap.
At least goal 2 is reached, goal 1 not really (maybe I will use a choke instead of a ferrite bead), goal 3 hopefully
Kind regards
Franz
Old 2nd January 2007, 03:30 AM   #14
I got mine today and so far I'm pretty happy with it. I haven't tried it with a battery yet, just the supplied plugpack. Compared to my project 85 CS8414/CS4334 DAC it is much quieter, and cymbals sound much more "real". I had no idea how tiny it would be though, that was a surprise! Will listen some more and report back.
Old 3rd January 2007, 06:31 PM   #15
Franz G's Avatar
Modifications, step 2:
I removed the four greenish caps and attached my first version from the Broskie cathode follower:
It works.
But I will rebuild the cathode follower with "real" tubes (E188CC instead of 6111). The problem: One channel was not working, some short between anode and grid. Maybe the tube, maybe the strip board, I used (to small distance between the traces for about 200VDC).
Here, you can see the attachment points for the balanced out from the DAC, after removing the four caps.
Franz
Old 3rd January 2007, 06:35 PM   #16
Franz G's Avatar
This is the chassis, to build the "real tube" module...
Old 4th January 2007, 07:14 PM   #17
Franz G's Avatar
Work in progress...
Old 5th January 2007, 02:54 PM   #18
matt J is offline matt J  England
Not very impressed with mine, what difference should I be hearing compared with say a standard internal DAC from a marantz CD67? night and day? I have connected the DAC via coax and optical and with the standard RCA out connected to the amp I can quickly switch between the DAC in box and the marantz via the input select on the amp, cant hear any difference what so ever
Old 5th January 2007, 09:31 PM   #19
Franz G's Avatar
Not impressed?
What power supply are you using?
Franz
P.S.
Coax AND optical connection?
Old 5th January 2007, 09:32 PM   #20
Have you tried it with a battery? I was going from an a pretty average dac to this one so a definately noticed a difference. I might be wrong, I'm very new to this, but isn't the CD67 pretty good to start with? Remember it's a pretty cheap little unit!
All the best.
Chinese DAC in a Box: CS8416 / CS4397Hide this!Advertise here!
CS8416/CS4397 board at 96kHZ? jonners Digital Line Level 81 19th February 2015 05:24 PM
CS4397 I2C Mode Mush Digital Line Level 0 29th April 2009 02:49 PM
CS8416 CS4397 24bit/192KHz DAC, FULL ASSEMBLED KIT pftrvlr Swap Meet 1 14th November 2008 04:10 PM
CS4397 and Zapfilter II N.S. Digital Source 10 31st January 2008 02:36 PM
