Simple I/V for TDA1541
Old 6th April 2010, 04:19 PM   #91
powerflux is offline powerflux  Netherlands
i've built the circuit, and when the volume on the cd is low, it sounds fine. but as soon as samples come above a certain level, they transform to a harsh 'click' or 'pop'. all initial adjustments have been done, but even when seriously offset (try and error-method), the behaviour doesn't change. both channels have the same problem
is hfe very important?
Old 14th April 2010, 05:05 PM   #92
robertor is offline robertor  Hungary
robertor's Avatar
hi everybody.
i just bought the last lampucera DAC:
2010 NEW VERSION 24bit/192khz DAC Kit su eBay.it CD Players Recorders, Home Audio, Electronics
who use the opamp, in this case the NE5532, as the I/V conversion stage.
the schematic appear on the first post of this 3D can be used also to replace this type of opamps?
the third opamp you see is for the output and will be replaced by opa627 or audio-gd MOON.
thanks everyone.
rob
rob
Old 17th April 2010, 12:10 AM   #93
SoNic_real_one is offline SoNic_real_one  United States
You need DUAL OpAmps to replace those - 2xOPA627 need to be mounted on a brown-dog adaptor.
Personally I didn't want to complicate thinks. I liked the best the sound of LM4562.
Old 19th April 2010, 10:34 AM   #94
robertor's Avatar
ok, then nothing "discrete stage" replacing the opamp.
that will be a big problem.
will come back the opamp rolling.
rob
Old 22nd April 2010, 07:58 PM   #95
mootzeroni is offline mootzeroni  United States
fyi, we were just discussing this DAC's opamps a few topics up on the forum:
New Small DIY Gigawork Dac? - diyAudio
I'm burning-in a Burson module in the output now, the other guy recommends LM4562's in the I/V. Those OPA Sun, Moon and Earth modules pique my interest as well...
Old 4th May 2010, 07:39 AM   #96
regal is offline regal  United States
See the Pass D1 for Sabre thread, thats the only discrete I/V stage I have seen that handles differential output DAC's.
Old 22nd November 2010, 03:18 PM   #97
totohung is offline totohung  Hong Kong
hi, i want to know what part to choose for the CCS i-dac?
Old 2nd November 2012, 02:58 AM   #98
Tubeee is offline Tubeee
Default how to increase the output level
Hi powerflux, and anyone who can help
I built the original circuit from rbroer too, but I didn't encounter the problem of click and pop, but I did find out that the output level is low., only 1.1V or so.
Does any one can help me to increase the output level to 2.5~ 3 V??
Any resistors or setup to increase the gain??
I know this is an old thread but since I built so I would like to know how to do further, hope someone can help!!
THX
Old 13th October 2013, 08:32 PM   #99
philpoole is offline philpoole  England
Hi Tubee,
I've built a couple of these recently, and I get the same low output.
As a stopgap, I'm using a simple opamp circuit afterwards, with a gain of about 10.
Seems to bring it up to a more usable level (not that I'm actually measuring anything).
Unless I'm doing anything wrong (I'm using rbroer's first Jocko's IV stage, but doubled the output resistance), I shall begin on a discrete gain stage and buffer.
Phil
Old 20th November 2015, 04:32 AM   #100
hollowman is online now hollowman  United States
hollowman's Avatar
I'd really wanted the Simple I/V for TDA1541 (v1 per OP) to work!
I'd had great results with Rudolf's similar I/V for TDA1545A (diyparadise).
Alas, after multiple build attempts, I could not get the I/V to work; I moved onto the similar Jocko I/V and similar no-go.
How many of you reading this have successfully implemented the orig. circuit (v1, see OP) to work?
Refs:
DIYHiFi.org -- I/V and whatever comes after it
"I got banned from a Hi-Fi forum. And I liked it."
- Luv, Katy "Hollowman" Perry
Simple I/V for TDA1541Hide this!Advertise here!
Less simple I/V for TDA1541 rbroer Digital Line Level 59 5th December 2007 05:56 AM
Simple, SIMPLE Digital volume control -_nando-_ Digital Source 5 21st December 2006 01:20 PM
Simple answer required for a simple question... rabbitz Multi-Way 4 31st August 2003 10:05 AM
