| Digital Line Level DACs, Digital Crossovers, Equalizers, etc. |
#81 | |
You may say so but to me you have covered considerably more ground than me, at leat on digital, , so all your comments and experiance are welcomed. Yes, been minimalist it is a compliment from my poit of view so congratulations for your implementation and as I said I'm willing to try somethig like these in the near future. Now I wait and see if these other guys shead some light on my twisted LM6181 CFB (I/V) analog stage, if they only took the boder to read my posts..... |
#82 | |
diyAudio Moderator Emeritus
TDA1543 is Iout DAC chip.
It's only audio |
#83 |
In that case I have to try it with TDA1541. This is all still new to me
www.audiosector.com “Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC |
#84 |
Banned
Peter:
Never tried the Jensen 1:1 output trannies......only the 4:1 step-down input types. They have the advantage of having really good CMRR. Please note that their input and output types are not interchangeable. I don't think either are very fond of DC offset, although I have no idea as to their B-I curves. Perhaps that could explain some of your disappointment. Jocko |
#85 |
diyAudio Retiree
Peter:
"I used the transformer right after I/V resistor and coupling cap." Jocko: "I don't think either are very fond of DC offset Perhaps that could explain some of your disappointment." How much DC offset is there on the other side of the coupling cap? You definitly don't want to put several volts of DC on the transformer winding. Maybe I can get a job as an editor............. |
#86 |
Do you feed this directly into your preamp or I would think some LP filter with gain?
Tom EE |
#87 |
Can anyone post a schematic to show how Rudolf's schematic at the beginning of the post can be adapted to a differential current output dac like the ad1853 so that there can be a singe ended output?
Thanks in advance |
#88 | |
Are all Q's now 2SA970's & 2SC2240's? What are the values for R1, R6 and R7 (are these best off as pots)? Are the LED colors still green ... or will red work better ... or does it really matter? For anyone who built the orignal and the folding-cascode "upgrade" ... how big of a sonic difference is there between the two? Thx for any info you can provide. |
#89 | |
Did you sim or measure how much distortion this first version of your circuit do have ? Thank you Bye GAetan |
#90 | |
Can i substitute 2n3904/6 for the 547/57? Their specs are very similar... Thanks! |
| Less simple I/V for TDA1541 | rbroer | Digital Line Level | 59 | 5th December 2007 06:56 AM |
| Simple, SIMPLE Digital volume control | -_nando-_ | Digital Source | 5 | 21st December 2006 02:20 PM |
| Simple answer required for a simple question... | rabbitz | Multi-Way | 4 | 31st August 2003 11:05 AM |
| Page generated in 0.22144 seconds (52.23% PHP - 47.77% MySQL) with 11 queries |
