Simple I/V for TDA1541 - Page 6 - diyAudio
Go Back   Home > Forums > Source & Line > Digital Line Level
Old 17th May 2003, 02:47 PM   #51
Thumbs up jocko
do you sell those magic boards...?
Old 17th May 2003, 04:14 PM   #52
Banned
Default Which one???
This thread started back when I was on vacation, so I missed the bulk of it. I believe that something extremely close to it is up here.
Another thing to remember.......I made the board in one night.....it had to fit into the existing board space that the CFB design was in. I did just enough to make it work, in very little time, to save my company from massive dealer revolt. It was never "tweaked", and there is ample oppurtunity for such.
So unless I am wrong, there is a good starting point here already.
Elso:
The reason I "tweaked" you is because I believe that I read something like "Feeback seems to be a four letter word to Jocko".
No, it is not. But the sound that the '846 I/V yielded nearly cost us all our dealers. It did so many things right, but what it did that was wrong was something none of them would accept in a highly competitive market. Ergo, it needed to be fixed.....ASAP, and the fastest, and apparently best solution, was to rip apart an '846.
Or you can do what Thosten did......evolve the I/V into a CFB.
They both use a common-base input stage and current sources/mirrors out the wazoo.
The reason I don't just post it and say: "Here, build it" is so that you guys can learn to like a designer. I believe that I can be of much more help in getting you guys to work this stuff out on your own........furthering your understanding.......than I would by just selling surplus boards (which are gone, sorry......) accompanied with a poorly drawn hand schematic.
(Yes, along with no simulation software, I have no schematic capture software either. What a dinosaur I am.)
Jocko
Old 17th May 2003, 10:34 PM   #53
apassgear's Avatar
Well I read most of both threads again dealing with this I/V issues, trying to figure out whats going on. Quite frakly I feel naive when comming to design and more so within this seemingly esoteric arena.
My simple question was regarding the implementation of the LM6181 to this task, since what I can hears is realy nice, but of course I oppened the pandora box once again.
If there is not a straight awnser to my question and if Jocko continues to hold the "secret" (for some reason I don't understand) behind the non feedback I/V I will give a try to Kuei's open proposal for the use of OPA660 which might even be better than Jocko's esoteric design.
Still for appling the OPA660 I have some questions regarding the +2mA compensating current required. Is it mandatory? Reading Kuie's post it seems to me that that is an open question.
To summ up for what I'm looking for is the simplest I/V with the best sound available today to be applided to an oversampling TDA1541A. Rails could be anything.
Any suggestions???
Reader's Digest style please (TM)
Happy listening!!!
Old 18th May 2003, 09:24 AM   #54
A oversampling TDA1541A, stock, or DIY? Could you tell someting about your circuit and components.
Thijs
Old 18th May 2003, 04:42 PM   #55
apassgear's Avatar
The CDP is a regular Magnavox CDB650 which was Pooged many years ago it has an SAA7210 decoder and SAA7220 Filter and a TDA1541A S1 DAC.
On the analog section had an AD846 (not shure, but it is a CFB opamp which was proposed originaly by Jung) keeping part of the original analog filter. Later I've been trying to replace it with an LM6181 CFB without any analog filtering.
The analog section PSU is using dedicated Jung/Sulzer super reg at (+)(-) 15V without the sensing option.
Hope I don't forget something important.
Old 18th May 2003, 04:46 PM   #56
apassgear's Avatar
Here is a pic of the unit before trying to implement the LM6181 analog section.
Old 18th May 2003, 04:51 PM   #57
apassgear's Avatar
Oopss... That was not the one I wanted to show, but this
Old 18th May 2003, 05:52 PM   #58
Peter Daniel's Avatar
Send a message via AIM to Peter Daniel
I just modified my Marantz CD-94 two days ago. I disconnected digital filter, so it's non oversampling now, changed and upgraded all electrolytics to Cerafine and HFQ, with ceramic bypasses at the pins. The output stage is using only first IC and I put OPA627 there in original config. Form output of OPA627, the signal goes directly to RCA jacks. I'm using 4.7 BG N for coupling, but I'm tempted to remove them. The resistors network at TDA1541 output was removed. It is still not finished yet (new clock and reclocker will be added, with new PS regulators) but as it is now, the sound is very good.
www.audiosector.com
“Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC
Old 18th May 2003, 06:58 PM   #59
apassgear's Avatar
I appreciate your input Peter...
Since I am not satisfied with the CDP sound, been trying different approches to this I/V analog section but with my limited electronic knowledge I get frustrated, besides I don't get straight answers from the many well experianced guys around here such as say "you can't do that with an LM6181 so try this" or "your getting into deep waters so follow this approach." which has been the gereral attidude on DIYaudio forums.
Well, frustrated or not I continue to work on this CDP (at my slow pace). To beggin with, I'm quite amazed at all what it can be get from the TDA1541A, it's such an overwelming sound I get from the new opamp (minus the noise of course) that I will like to continue with original oversampling setup, for the moment.
One interesting thing with this "new" approach with the LM6181 is that I decoupled the chips rails with only one 1uf film cap very very near the pins which might be contributing to the excellent sound I'm getting.
On trying to solve the noise (thinking it could be PSU related) I tryed further decoupling adding a ceramic cap at each point plus a MKS 4 0.01u across both rails at the chip.
I had never before try to use ceramic caps, the regular types. The result after this addition degraded the sound.
Old 18th May 2003, 07:09 PM   #60
Those are not regular ceramic caps and the way I'm doing it is described here: The mods never end, adding Goudreau's triplets
www.audiosector.com
Less simple I/V for TDA1541 rbroer Digital Line Level 59 5th December 2007 05:56 AM
Simple, SIMPLE Digital volume control -_nando-_ Digital Source 5 21st December 2006 01:20 PM
Simple answer required for a simple question... rabbitz Multi-Way 4 31st August 2003 10:05 AM
Copyright ©1999-2017 diyAudio
