USB to SPDIF converter, or that combined with good DAC - Page 3 - diyAudio
Go Back   Home > Forums > Source & Line > Digital Line Level
Old 30th January 2008, 03:14 PM   #21
FastEddy's Avatar
" ... I need an SPDIF to USB converter. ..."
M-Audio Transporter = bi-directional SP/DIF optical input and output at "CD quality or better". @ m-audio.com
Old 31st January 2008, 04:21 PM   #22
The DA30 has AES/EBU or coax spdif only.
Old 31st January 2008, 04:38 PM   #23
Banned
There's the very cheap Behringer UCA202 USB DAC, only 1648, but has optical out and headphone socket ...
http://www.zzounds.com/item--BEHUCA202
w
~ $30 US
Old 31st January 2008, 04:44 PM   #24
FastEddy's Avatar
A piece of advise ... as long as you are getting a DAC, you should also get an ADC with it. The chips cost about the same for output only or input and output.
You do want to capture audio as well as play it back, right? ... Rip AND roar?
Old 6th October 2008, 10:15 PM   #25
This one looks great value. What do you guys think?
http://cgi.ebay.co.uk/MINI-HI-FI-USB...3286.m63.l1177
Old 6th October 2008, 10:40 PM   #26
FastEddy's Avatar
Check out the DAC chip first: PCM2704 DAC = 16 bit "el cheap-o" http://focus.ti.com/docs/prod/folder...t/pcm2704.html
Old 7th October 2008, 11:25 AM   #27
The reason many manufacturers use the 2704 (or similar), is not because it's is "el cheapo", meaning crap. It's because it's a very good quality DAC and easy to implement. at a reasonable cost.
Yes, it can only do 16 bit, 48KHz, but this is because it's a USB DAC. To implement USB, proprietary software has to be written and this is not viable for many small companies.
The DAC's they are making are very good, just limited to 16/48 because of USB. Some of the DAC's that have SPDIF as well as USB allow 24/96 via the SPDIF, but still only 16/48 via the USB input.
Old 7th October 2008, 02:07 PM   #28
A 8 parallel TDA1543 + Dir9001 based USB DAC
http://cid-8af16b7a94a5dc53.spaces.live.com/blog/cns!8AF16B7A94A5DC53!378.entry
It supports USB interface.
It was made a diyer in China, but the quality is good.
Besides, the price is not expensive.
Old 7th October 2008, 02:56 PM   #29
In my previous post, I meant to say to get USB to work at 24/96 requires software to be written. At 16/44.1/48, standard drivers can be used.
Sorry for the 4 letter word too. I didn't think that particular word would have been banned.
BTW, I think DAC's that have 8 separate chips, instead of 8 times oversampling is an interesting technique.
Is this a similar design? http://cgi.ebay.co.uk/moon-NOS-Nonov...3286.m63.l1177
Old 1st November 2008, 09:11 AM   #30
From the layout and components used in the two TDA1543x8 DAC, I believe they are from the same designers. One may be the upgraded version of the other.
USB to SPDIF Converter mp006ltk Digital Source 14 22nd March 2015 11:15 PM
USB to SPDIF converter rokoko Digital Line Level 12 8th July 2009 07:19 PM
Another USB to SPDIF converter Kane Williams Digital Line Level 0 10th October 2008 10:25 PM
GB of PCB's for USB->SPDIF converter at head-fi Nisbeth Digital Source 16 31st July 2005 12:33 PM
Copyright 1999-2017 diyAudio
