Music server with TDA1541 (I2S direct) - Page 2 - diyAudio
Go Back   Home > Forums > Source & Line > Digital Line Level
Old 12th April 2008, 05:08 PM   #11
Hello again Chuck
Looks like we have another equipment in common. Mine's the newer MU3100. But I have not mod at board level yet.
Didn't like the sound from the TVIX. I'm using its digital coaxial out to for connection to an outboard DAC. Had a Sarotech 2.5in HDD Player as a comparison, the Sarotech sounded better. I figured the 3.5 in HDD was vibrating too much (from the spinning) and giving off too much heat. So I replaced the 3.5in with a notebook 2.5in (using an adaprter) and took off the fan. Now it sounds much better. However, the 2.5in HDD is hanging loosely in the original casing. There is still a little vibration from the 2.5in which I will be looking for some rubber bungs to secure the HDD in place and isolate it from the case.
So far the sound has dramatically improved. Its more defined now, not muddy and hollow as before.
Old 12th April 2008, 05:53 PM   #12
edraket is offline edraket  Netherlands
hi RaZmaTaZ,
did you play some songs from flashmemory yet? I'm curious how it sounds.
eddy
Old 14th April 2008, 04:50 AM   #13
Edraket,
Flash memory? I'm waiting for the SSD to come down in price. Maybe next year huh. With SSD, it will be truly vibration free source. Right now its on hard disks (but the 2.5in instead of 3.5in) which has less vibration.
I'm playing music off the this modded TVIX and it sounds better than a regular CDP. (I'm using a NAD 515 BEE for comparison.) The sound is more defined, less muddy.
In comparison to the Sarotech 2.5in (palm size device) the TVIX sounded more fuller. The Sarotech being slightly shy on the bass. Overall, I'm pretty happy with the results.
Old 14th April 2008, 06:24 AM   #14
Default where did you get the m3100 in KL?
and how much?
tried sending you email, but could not.
or you can email me at
tinears at gmail dot com
would appreciate it.
thanks
YH
Old 3rd June 2008, 04:18 PM   #15
Originally posted by edraket
hi RaZmaTaZ,
eddy
Eddy
Got both SD adapter and a CF to SATA (from ebay) for the DVICO(TVIX) and the Sarotech and both dun seem to work. Both the SD and CF card works on a regular USB card reader but when I stick them in their HDD adapters, the music players dun seem to be able to read the flash disks. Any ideas?
Old 3rd June 2008, 05:13 PM   #16
Andypairo's Avatar
Default Re: Music server with TDA1541 (I2S direct)
Originally posted by ChuckT
Here is my 160GB server base on the TVIX module with TD1541 and I2S tapped from the TVIX board.
Output stage is a variation of Mr Pass D1 (jfet circuit thanks to stefanobilliani)
And the sound is the best I had so far. It was a big jump in quality when dropping the cs8414 and go I2S direct.
Here's a pic. Everything in a wooden box.
I have a question about this interesting mod: do you have schematics for this board or you reverse-engineered it?
Btw does the tvix have its own "audio" clock?
Cheers
Andrea
I don't believe in audiophile components - except when I can get them at frugal-phile(tm) prices
Old 14th June 2008, 09:26 PM   #17
Andypairo's Avatar
Default Pinging ChuckT
Hi Chuck,
in case you missed the question: how did you find where to tap I2S from EM8511?
Did you manage to get a datasheet?
Cheers
Andrea
Old 15th June 2008, 12:55 AM   #18
brianuk is offline brianuk  United Kingdom
interesting, anyone know what current models allow access to I2s ?
For example this one?
http://www.amazon.co.uk/DVICO-TVIX-M...3487068&sr=1-3
Suprise this thread wasnt a lot busier.
Old 30th June 2008, 10:09 AM   #19
Andypairo's Avatar
It is all related to the DAC used.
For multi-format DACs you should also know how are programmed the mode selection bits.
Too bad there is so little info!
If IIS not available there is also the (worse) SPDIF output.
Cheers
Andrea
Old 22nd August 2010, 01:55 PM   #20
erin is offline erin  Australia
Default TDA1541 i2s with WD mini
Just thought I would pop in and contribute.
I just hooked up my WD TV Mini Media Player ( WDBAAL0000NBK ) to my Analogmetric TDA1541 DAC using i2s and so far I think it is at least as good as my usual source which is a fully optimised CMP + Cplay computer with teralink x (1) USB>i2s converter. I tentatively think the WD might be better. I heard more details and better decay of sound, and HF sounded like it went higher and clearer.
I checked the i2s lines with my CRO and I find the signals to be very square with no ringing or overshoot. This is very promising.
I will do more testing tomorrow.
I got some tips with doing this from here: http://community.wdc.com/t5/WD-TV-Mi.../DAC/td-p/5259
The only thing disappointing about the WD mini is the lack of gapless playback.
Latest USB converters or music server? dublin78 Digital Line Level 0 11th February 2009 07:29 PM
Music Server JC951t Digital Source 6 6th August 2008 07:47 AM
Digital Audio Music Server kevinkr Digital Source 79 25th June 2008 05:29 PM
Wireless music server mods anyone mlihl Digital Source 12 8th November 2006 01:54 PM
Reclock music server ackcheng Digital Source 3 28th February 2005 03:21 PM
Copyright 1999-2017 diyAudio
