DCX2496 EQ functions
Old 6th July 2006, 08:57 AM   #21
compact7 is offline compact7  Singapore
Hi Rob,
You say Q=10 is pretty narrow. I still do not understand what is the Q really mean. Is 1/6 oct bandwidth = Q = 6? 1/10 = Q = 10 in DCX?
Listen and Enjoy
Old 6th July 2006, 05:02 PM   #22
RobWells is offline RobWells  United Kingdom
RobWells's Avatar
Have you downloaded the software as was suggested above ?
It shows you graphically the shape of the filters and their bandwidths.
Rob.
Old 6th July 2006, 11:01 PM   #23
catapult is offline catapult
As Rob said, the best thing is to download the software so you can see the shape of the curve and adjust the DCX directly with your PC. It's much more intuitive than the kludgey way the BFD does things. You can see how gain as well as Q both have a big effect on the shape of the curve.
If anyone cares, you asked for it , the formula for converting bandwidth to Q in Excel notation is:
Bandwidth (octaves) =
LOG10((2*Q^2+1)/(2*Q^2)+SQRT(((((2*Q^2+1)/Q^2)^2)/4)-1))/0.301
Some examples:
Q -- Octaves
0.1 -- 6.7
1 -- 1.4
10 -- 0.14
Old 7th July 2006, 05:03 AM   #24
I had download the program. I also downloded the REW. I had a little bit understand on the Q now. The Q = Bandwidth. Am I right? So if I want to to apply 40hz at 1/6 oct so I need to set the DCX Q to 6. So the narrowest I can go with DCX is 1/10. The BFD can go 1/60.
So I can use the low Q to pull/push a particular bandwidth and high Q to tampping a particular peak or null in my room or bass from my sub.
Am I right now? Please corect me if I am worng
Listen and Enjoy
Old 8th July 2006, 12:17 AM   #25
Any one can correct me??
Listen and Enjoy
Old 8th July 2006, 09:11 AM   #26
R.I.P.
Hi Rob,
AndrewT - it sounds to me like you took it out the box, played for an hour or so and packed it away ?
you are nearly right.
I used it for about six weeks trying various filters and equalisations. I usually listened to each implimentation for about a day.
But, I could never get the immediacy and impact in the treble. It always seemed soft with missing detail and the low bass rolled off far too early. I even tried exagerating treble with eq etc. and never got it to sound right.
I was following the threads on altering the input and output stages at the time and became convinced that another project to "improve" DCX2496 was needed to meet the standard set by the manufacturer's passive crossover. Then I packed it away until time became available.
It certainly did not meet my standard for stereo listening.
I still hope it will give me a solution for surround sound and delay for the main speakers relative to horn distance.
regards Andrew T.
Old 8th July 2006, 09:52 AM   #27
RobWells's Avatar
Hi Andrew,
There was meant to be a smiley after that line btw - went back to edit it but couldn't.
What setup were you using it in as I cannot hear a lack of detail in my tweeters at the moment (JBL 2402H)
I'm planning on trying a passive between my mid and tweets though, as they are often used with 1st order slopes. It will be interesting to see if it improves the sound quality, what with the lack of eq and delay from the passive.
Hows your subhorn coming along ?
Rob.
Old 8th July 2006, 09:57 AM   #28
RobWells's Avatar
Thats what I do. No need for my BFD or my DEQ now.
Rob.
Old 8th July 2006, 10:08 AM   #29
RobWells's Avatar
What you have to ask yourself with the very narrow filters is if they are worth the effort - move your head left or right a few inches and the response changes. If your going to do this properly you need to measure with an rta at all listening positions and then decide where to eq.
For example theres an un eq'd plot of my labhorns here :
If I boost the 80Hz - 100Hz null on the purple line then the yellow and green lines would have huge boost at those frequencies. The purple line is in the middle seat of a 3 seater couch, the yellow and green are the seats either side.
Rob.
Old 10th July 2006, 08:16 PM   #30
R.I.P.
Hi Rob,
sub, slowly, very slowly.
But timber being screwed between the rafters and loft floor to hold horn sides in place.
regards Andrew T.
DCX2496 EQ functionsHide this!Advertise here!
are all functions patterns? Chris8sirhC Everything Else 25 22nd March 2009 06:09 AM
Have anyone played with Alpines Ainet functions? FE3T Car Audio 0 14th September 2008 11:24 AM
how to disable auto functions on DD turntable kirk57 Analogue Source 8 25th February 2008 04:39 PM
DCX2496 EQ functions compact7 Subwoofers 0 31st May 2006 01:18 PM
Transfer functions? oracel Multi-Way 15 23rd October 2004 01:34 PM
