Building the ultimate NOS DAC using TDA1541A
Old 21st June 2018, 12:54 PM   #6201
lcsaszar is offline lcsaszar  Hungary
Originally Posted by SSerg View Post
The TDA1541 (A) chip accepts input data in only two formats: OB or TWC. In both formats, the MSB is interpreted as a signed bit.
Actually there are three formats: simultaneous, time MUX OB and time MUX TWC.
Old 21st June 2018, 02:22 PM   #6202
SSerg is offline SSerg  Russian Federation
Hi lcsaszar,
Please read to the end of page 4.
Old 24th June 2018, 10:47 AM   #6203
ecdesigns is offline ecdesigns  Netherlands
Hi SSerg,
I found time to read the message No. 6116. The idea is good. This is called a segmented DAC.
Indeed, in this way it is possible to significantly reduce the interference from the conversion of the digit / analog near zero.
But to implement the 17-bit DAC on TDA1541 (similar to PCM1704) will not succeed.
In the PCM1704 chip, the conversion of numbers to the desired format is done inside the chip, and as a result, each of the two internal DACs operates in a dedicated 23-bit segment. Two 23-bit DACs, each working in its 23-bit segment, result in a single 24-bit DAC.
The size of each segment for the TDA1541 pair is 15 bits, since it is impossible to transfer a 16-bit natural number inside the TDA1541 (A) chip, only 15-bit. One bit (MSB) is inevitably spent on the sign of a number. Two DACs, each working on its own 15-bit segment, will result in a single 16-bit DAC.
Not quite, I use the -most significant- 15 bits for 16 bit resolution and all 16 bits for 17 bit resolution. I also indicated that the full scale current equals 8mA.
When I combine two 16 bit segments I can get 17 bit accuracy, this is how all segmented D/A converters work.
At the zero crossing we get:
1111111111111111 (65535)
While the other channel (segment) is completely turned off (all 16 bits low):
0000000000000000 (0)
So none of the segments is programmed at 32767 (-2mA) at the zero crossing.
The MSB is first sampled (stored) then removed from the code that enters each segment. MSB only governs the data flow into both segments.
Every amplifier-speaker combination distorts quite a lot, then a tiny LSB error becomes irrelevant.
However, among all this distortion, our auditory system remains very picky about zero crossing behaviour (think of audible cross over distortion in push-pull amps). So it still makes a lot of sense (at least to me) to do something about it.
Old 24th June 2018, 11:30 AM   #6204
Hi John,
PCM1704 forms two 23-bit segments from the input 24-bit code within itself. From the 16-bit code (in the format of OB or TWC), you can form two 15-bit segments.
TDA1541 will accept MSB of the incoming digital word as a sign. If you delete the MSB from the source digital code, the contents of the next bit (the 2nd bit in the source code) will be accepted as a sign.
Old 24th June 2018, 05:46 PM   #6205
Hi SSerg,
I indicated that I either use the most significant 15 bits of each channel / segment for a 16 bits segmented DAC:
111111111111111-
Or all 16 bits of each channel / segment for a 17 bits segmented DAC:
1111111111111111
Perhaps I was not clear about the fact that I combine L channel (segment #1) and R channel (segment #2) to form one 17 bit mono DAC with one TDA1541A chip. So I need two TDA1541A chips for stereo.
I use a decoder that formats two different data streams, one for each segment. I use TDA1541A simultaneous interface, pin 27 tied to -5V.
Yes, but the related 16 bit L & R channel zero crossing will be shifted 32767 positions away from the newly created signal zero crossing.
This newly created zero crossing is composed of -4mA from one segment, 0mA from the other segment and +4mA from an external bias source, -4 plus 0 plus +4 = 0mA.
With the datasheet application the zero crossing is between these codes:
0111111111111111
1000000000000000
The newly created zero crossing in the segmented version -combines- these codes:
0000000000000000
1111111111111111
These no longer coincide with the actual zero crossing in each 16 bit channel / segment segment.
Old 25th June 2018, 12:48 PM   #6206
Shinja is offline Shinja  Japan
Hi ec. It looks your circuit forgot to add 1LSB at -1 to +-0 transition.ie,
input 011...1(17bit) converted to 000...0 plus 111...1(16bit)
input 100...0(17bit) converted to 000...0 plus 111...1(16bit) you need 1LSB here as PCM1702/4,
or you can add 1 to the data at the transition and treat wrap around at 111...1 input somehow.(let it clip there it is just a 1LSB short from normal.)
This is little complexed because serial-parallel-serial conversion and a adder are needed so it is better implementing little PLDs.
I also considered sign magnitude with 1541 but not built from my laziness. I will keep eyes on your work.cheers.
edit
The output format is simultaneous then you need to invert MSB for TWC, SSrg mentioned this?I could not understand his post well.
Old 25th June 2018, 02:53 PM   #6207
Hi John,
I have no doubt about the possibility and usefulness of creating a segmented DAC based on TDA1541.
I just insist that the resulting segmented DAC will be 16-bit, not 17-bit. The reason is simple: there is nowhere to take a 16-bit mantissa of number. The input signal contains a 15-bit mantissa (15 bits) of sample and a sign (1 bit) of sample. Total 16 bits.
Old 25th June 2018, 03:26 PM   #6208
Alexandre is offline Alexandre
It depends on what player is used. Are there any PC players that would allow adjustment of dither level and wordlenght?
If there arenīt any, maybe a JRiver dither plugin can be created. I would disable JRiver internal dither and use the plugin.
I have looked briefly into creating such a plugin, thereīs a software called Flowstone that facilitates development of audio plugins and export as "VST" that can be used in JRiver. IIRC, two independent/uncorrelated random number generators are necessary to make good TPDF dither. I could use one of the provided examples in the Flowstone forum for a random generator, but Iīm not sure how to create a second independent generator. I didnīt look at noiseshaped dither yet.
Thanks,
Alex
Old 25th June 2018, 03:51 PM   #6209
Hi Alex,
No, it depends primarily on the capabilities of the DAC chip.
Old 25th June 2018, 03:56 PM   #6210
SSerg, are you talking about sign magnitude binary code? Indeed, the DAC in discussion is not straight sign magnitude structure but it matters?
For example if we use 4 quadrant multiplying DAC and switch reference polarity with sign bit, it is the sign magnitude, but it must produces massive glitch at zero crossing.Some other circuit can be designed but I think 2DAC(+1LSB) sign magnitude is good choice as PCM63, PCM1702/4 does. Weakness of this configuration is gain matching of upper/lower DACs.
Building the ultimate NOS DAC using TDA1541AHide this!Advertise here!
