Building the ultimate NOS DAC using TDA1541A - Page 495 - diyAudio
Go Back   Home > Forums > Source & Line > Digital Line Level
Old 15th September 2013, 02:53 PM   #4941
maxlorenz's Avatar
I use proper copper rods on my dedicated circuits (though one has cable TV and web connection) and balanced power transformer, which is not exactly isolation transformer.
I like balanced power
M.
Old 15th September 2013, 05:53 PM   #4942
hi ecdesigns,
could you tell me how i would be able to float pin 7 of 1543 if i was using active i/v stage such as zen or ad844?
and is there any other trick that can be performed for the pair of 1543 in balanced config with flipflopped data?
thank you.
i've been toying with 1543 since the beginning of this year and your pin float mod still stands as the most dramatic improvement to the chip, yet. i also was regarding your i2s signal attenuation circuit with diode strings but found out that it was reducing the gain in a balanced config where the data signal is fed through 74hc04 hex inverter.
when i disconnect the diode string the gain would go up.
Old 15th September 2013, 11:03 PM   #4943
jstang is offline jstang  United States
Could you drive a copper rod into your soil ? Mine would look like a pretzel....I need the copper clad steel.
These grounds improved the TV cable reception....
M.
Old 16th September 2013, 10:49 AM   #4944
Bernhard's Avatar
And the winner DAC chip is...???
Let me make a guess: PCM56
Old 16th September 2013, 01:43 PM   #4945
triode_al's Avatar
It can't be connected to I2S, can it?
SPU --> tube MM/RIAA; Kaneda pre; 300B SE driven by ECC35; Open Baffle PM2A, 2A9
Old 16th September 2013, 08:37 PM   #4946
Bernhard's Avatar
Use I2S for what ?
Old 17th September 2013, 06:36 AM   #4947
SSerg is offline SSerg  Russian Federation
Hi, Shinja
Originally Posted by Shinja View Post
This tweak may make worse chip to be better performance, or typical chip to catch S2 spec, I expect.
Interestingly, you yourself have used this method? Can you tell me what are the results?
This tweak is unsuitable for passive IV circuit.
This is not entirely true. You can create a constant bias voltage across the I/U resistor.
Old 24th September 2013, 03:56 AM   #4948
M.
Whats the difference between that and a iso transformer?
I use a EMI common mode mains filter for my dac and it definitely makes a difference for the better. Itīs a delta electronics, sealed can, I took it from a no-break.
Old 24th September 2013, 04:00 AM   #4949
I have been browsing this thread, looking for ideas to improve my dac, and something struck me here: the dedication and diligence of John and how much he has given here.
John: Your work is much appreciated! This thread is invaluable for any serious diyer.
Best regards,
Alex
Old 24th September 2013, 11:22 AM   #4950
maxlorenz's Avatar
Hi. These guys explain it better than I could:
Index of Technical Articles About Balanced Power
Yes, his approach is like analysing with a magnifying lens every step of the chain and he has shown that every single part of his low parts count DACs matters to audio...
M.
Copyright Đ1999-2017 diyAudio
