Building the ultimate NOS DAC using TDA1541A
Old 12th April 2013, 08:28 AM   #4821
marconi118 is offline marconi118  Germany
Does it mean that the whole generation chain of I2S signals has to be CML / ECL?
I plan to do a balanced 2X TDA1543 NOS, needing to invert the data line of one of the TDA1543
any CML / ECL inverter buffer to do this?
I2S signals will come from a squeezebox or async USB receiver
Old 12th April 2013, 10:27 AM   #4822
maxlorenz is offline maxlorenz  Chile
maxlorenz's Avatar
Something like this?
https://picasaweb.google.com/lh/phot...eat=directlink
Though I don't know if the chips are CML/ECL or whatever...
I only follow instructions.
M.
Old 12th April 2013, 02:09 PM   #4823
I need something more simple, an inverter like 74ACT14 or 74ACT86 in CML / ECL
It has only to invert the polarity of the I2S data line
Old 14th April 2013, 10:26 AM   #4824
studiostevus is offline studiostevus  Netherlands
I am still pondering the ideal BCK supply to the tda...
ECdesigns: Building the ultimate NOS DAC using TDA1541A
In the latest projects I use a high speed / low jitter divide-by-4 circuit running on 1.8V (1.8Vpp output signal). I feed this 1.8Vpp BCK signal to the TDA154x using only a 180R series resistor.
BCK is extremely critical, attenuators are best avoided here, even plain series resistors are a problem (noise). Best results can be achieved by using 800mVpp BCK signal (not derived from an attenuator) with less than approx. 300 Femto seconds of jitter, but this is kind of "problematic"
So simply remove the BCK attenuator and hope for the best.
The ideal BCK trigger needs to be:
- jitter-'less', so as few components between the source and the tda.
- as low voltages as possible to avoid on-chip interaction.
- but minimum 1.8V to trigger
- difference between 'low' and 'high' must be at least 800mVpp.
So the ideal BCK signal would be between 1V and 1.8V.
My divide by 4 circuit consists of 2 74AUCG1 flipflops. I have a variable supply voltage to it, so I can fine tune the output of it. At this moment I have connected the flipflop directly to pin2 of the TDA.
The result of this is that the BCK signal is low at gnd, and high at 1.8V (I have test to go below 1.8V, and then it doesnt trigger the tda anymore, in line with john's findings.
So the likely thing to do would be to pull up the 'low' to 1V (or a bit less, like 0.9V) and leave the 'high' at 1.8V. Risk of course is injection of some additional supply noise into the signal, thereby increasing jitter....
TDA1541a-S2 / 6072a / MediaplayerDac -- Michell Gyrodec -- Aikido Preamp -- Pass F5 -- Audio Physic Tempo 2SE -- Yamamura Cabling
Old 15th April 2013, 07:11 AM   #4825
ecdesigns is offline ecdesigns  Netherlands
Hi studiostevus,
I am still pondering the ideal BCK supply to the tda…
Ideal BCK divider (divide-by-4) can be built using ECL (> 4 GHz). Signal swing would be 800 mVpp and typical jitter contribution would be 200 Femto Seconds.
When the bias voltage is corrected to 1.2V, the clock signal would then swing between +0.8V and +1.6V.
When using 74AU1G74 D flip-flops (typical 2.5ps jitter contribution for each D flip-flop) one could do following:
2.2V power supply (buffered 2.7V zener for example).
Anti-parallel 1N4148 diodes between Q output and BCK:
Q >| BCK
Q |< BCK
100R resistor between /Q output and BCK.
This would result in BCK signal swing between +0.6V (Q = "0" and /Q = "1") and + 1.6V (Q= "1" and /Q = "0").
Old 15th April 2013, 10:05 AM   #4826
Originally Posted by -ecdesigns- View Post
Hi studiostevus,
Q >| BCK
Q |< BCK
Hi John, thanks for your note.
The 74au d flip flop solution is essentially the one you used a year ago in mk7 or so.
I am wondering whether using 2 diodes (jitter contribution) and a resistor (noise) to improve the ttl levels to reduce on-chip crosstalk, is a better solution than just leaving the ttl as is (Vlo=0v, Vhi=1.8v), having less jitter on the incoming bck signal and accepting the on-chip crosstalk....
Have you done any research on this perhaps?
Old 16th April 2013, 01:54 PM   #4827
In the meantime I tried the following:
74auc1g flipflop Q to pin2, and the power supply (1.8V) to the flipflop with series resistor 68R to pin2 as well. This lifts up the 'low' state to about 0.7V. So far seems stable and works fine.
Haven't yet properly compared to the situation without the pull-up resistor. Will do that tomorrow.
Old 18th April 2013, 01:27 PM   #4828
SSerg is offline SSerg  Russian Federation
Reading this article (http://www.unitest.com/theory/jitter.html),
I have come across on interesting picture.
Upper curve - a clock pulses (456 MHz), blue histogram - a histogram of the point of the transition.
The blue line - TIE (Time Interval Error – TIE), red line - a FFT for TIE that is to say the jitter spectrum.
Old 27th April 2013, 05:42 PM   #4829
triode_al is offline triode_al  Netherlands
triode_al's Avatar
Originally Posted by Xpertv
Is it necessary to add 2mA to TDA1541 outputs while I\U is provided by OpAmp? (Stock variant like NE5532\LM833) Or this is only for resistor I\U?
Originally Posted by SSerg View Post
According to TDA1541 datasheet this is not required.
But if I/U is provided by opa-amp, accompaniment of 2 mA on output 1541 reduces the current through feedback resistor. This reduces the constant voltage on a opa-amp output (in ideal up to zero).
I have a nice Marantz DAC, TDA1541, and there we see separate 'channels' for the 2 mA bias current such that the I/V opamp is always at 0 volts, so no current feedback through the resistor; hence having an operating point with lowest distortion.
(apologies if I miss your point; Is this what you mean?)
albert
SPU --> tube MC/RIAA;
Pass buffer -->300B SE + DN2540 CCS/Buffer; --> 165GMF in TQWT; working on a HYPEXed sub.
Old 29th April 2013, 07:04 AM   #4830
Yes. Giving 2 mA on the opamp input, we install the zero voltage on the opamp output. This minimizes distortions.
Building the ultimate NOS DAC using TDA1541AHide this!Advertise here!
