Building the ultimate NOS DAC using TDA1541A - Page 482 - diyAudio
Go Back   Home > Forums > Source & Line > Digital Line Level
Old 10th April 2013, 10:24 AM   #4811
SSerg is offline SSerg  Russian Federation
Originally Posted by marconi118 View Post
If this is true, what about TDA1545?
TDA1545 and TDA1543 vastly worse, than TDA1541(A). For TDA1545 THD is equal -88 dB at level of the signal 0 dB (-95 dB for TDA1541) and -35 dB at level of the signal -60 dB (-42 dB for TDA1541).
Old 10th April 2013, 10:35 AM   #4812
and comparing tda1543 to tda1545?
Ecdesign mentioned earlier that 1543 is better than 1541 for SD player, less internal jiiter
Old 10th April 2013, 01:03 PM   #4813
THD for TDA1543: -75 dB and -30 dB for signal level 0 dB and -60 dB accordingly. Else worse, than at TDA1545.
I can't agree with this opinion. It is deeply wrongly.
Old 10th April 2013, 03:25 PM   #4814
abraxalito's Avatar
Location: Hangzhou - Marco Polo's 'most beautiful city'. 700yrs is a long time though...
Send a message via Yahoo to abraxalito
Should have an even better sound than 1543 without the DEM clock problems?
I've found that TDA1545A does sound better than 1543 but only when the output is carefully filtered to reduce the glitching. Being a CMOS chip it generates a substantial quantity of switching noise on its PSU. If the impact of this HF noise on the following circuitry isn't minimized, it sounds more gritty than 1543 despite posting better specs.
The heart ... first dictates the conclusion, then commands the head to provide the reasoning that will defend it. Anthony de Mello
Old 11th April 2013, 08:58 AM   #4815
Hi marconi118,
with state of the art applications with high time resolution it has many advantages to use a TDA1543
The SDV1-player was specifically designed to obtain highest possible time resolution with currently available (and affordable) parts. Feedback from audiophiles suggests that this is a -highly- desirable feature in digital audio sources.
Note that just using a TDA1543 in an application is meaningless without providing the environment required for obtaining highest possible time resolution.
TDA1545 is based on noisy CMOS logic (4mA supply current) and the continuous calibration causes similar problems like with DEM. So it is unusable for obtaining high time resolution.
The reason why I am no longer using ultra high speed CMOS circuits for clock, clock distribution, and DAC chip is that these have approx. 12.5 times higher jitter contribution compared to CML / ECL.
Typical jitter contribution of an ultra high speed CMOS (275 MHz): 2.5ps
Typical jitter contribution of CML / ECL (4 GHz): 0.2ps
The reduction of approx. 2.5ps to 0.2 ps is -very- clearly audible with NOS that is -least- sensitive to jitter.
The jitter spectrum is alo of greatest importance for perceived sound quality. So when jitter amplitude has reached its practical limits, further improvements can be made by tuning the residual jitter spectrum.
Old 11th April 2013, 09:11 AM   #4816
s3tup's Avatar
Afaik the main jitter bottleneck for ECLs was the ECL-TTL conversion which was worse than going with TTL all the way.
The missing link between lead and gold in alchemist's world was BS and commerce.
Old 11th April 2013, 10:22 AM   #4817
Hi, -ecdesigns-
How you offer to adjust the jitter spectrum?
Old 11th April 2013, 12:32 PM   #4818
Hi s3tup,
True, one ECL to TTL translator would contribute approx. 2.5ps of jitter. This would equal the jitter contribution of a single ultra high speed CMOS gate.
But why convert ECL to TTL when using TDA154x DAC chips that are already based on Current Mode Logic with typical 400mVpp signal swing?
ECL can drive TDA154x chips perfectly while providing very low jitter contribution.
Old 11th April 2013, 01:40 PM   #4819
Hi SSerg,
I use an electronic tuning fork. Phase noise spectrum tuning is mainly obtained by tuning the properties of the active single transistor drive circuit.
First oscillogram shows the drive signal (input node, 0.5V/div, 11.289 MHz).
Second oscillogram shows the signal on the primary node (1V/div, 11.289 MHz).
Third oscillogram shows the signal on the secondary node (1V/div, 11.289 MHz).
All 3 nodes are "isolated" for all frequencies but the fundamental (11.289 MHz). This prevents cross-pollution between connected circuits.
The microcontroller is connected to the primary node using a low pass fliter / attenuator
The PECL divider is connected to the secondary node.
PECL divider circuit outputs 800mVpp BCK signal with exactly 1.1V DC bias.
Old 12th April 2013, 08:13 AM   #4820
Ceglar is offline Ceglar  Australia
Banned
ah.. ok, so BCK does get biased up to 1.x VDC even though it receives no attenuation as per the previous questions/comments about 3.3V I2S feed.
Copyright 1999-2017 diyAudio
