| Digital Line Level DACs, Digital Crossovers, Equalizers, etc. |
#4781 |
Oliver,
FWIW...the Ian PCM board (I think) will require separate imputs to L and R on the DAC chip. Might this call for a jumper?.... |
#4783 | |
Hi dvb-project,
BCK needs to be around 800mVpp (approx. 1.2V DC bias) without using an attenuator, so this problem has to be solved in the BCK divider circuit. BCK overshoot (on the scope) is usually caused by an incorrect probe. One needs to use HF probes, something like this: 3GHz RF Probe Scope bandwidth also has to be large enough, 100 MHz bandwidth would be acceptable. I also suggest to "measure" with your ears after checking the signal with the scope. What looks good on the scope can still sound lousy |
#4784 | |
Hi AudioLapDance,
#4785 | ||
Without all parts i have the full BCK output voltage from Ian´s FIFO at PIN 2 and no Bias...? I think i have not really understood what to do...
Reference TDA1541A DAC project PCB´s / Tube-I-zator PCB / SSHV-Shunt PCB
Stock status in my Blog |
#4786 | |
Interesting stuff: he also mentions to prefer TDA1543 over 1541 because it [might be] internally less jitter prone and without external jitter (like in Johns implementations) the DEM logic of the 1541 has no advantage. . . Even though he boasts a non-tech site, it does sound techy . . .
DAC TDA1541 S1; MC30-Super --> two stage RIAA; SP-6 clone ; 300B PP: 6N7/ECC82, Metalimphy output.
#4787 |
I attached the BCK output signal from Ian´s FIFO.
#4788 |
is choosing a less facetious title...
looks better than that normally too, the roundover is likely a measurement artifact
#4789 | |
Hi dvb-project,
That's why I suggested to directly connect FIFO BCK out to pin2. This is the best compromise given the practical drive circuit limitations. I also suggest to use shortest possible connection between FIFO circuit and TDA1541A BCK input. With shortest possible I don't mean a few centimeters mut more like a few millimeters. If you want to experiment with a BCK attenuator you could try a similar diode attenuator like with WS and DATA. The pull-up resistor value then has to be lowered to 120 Ohms. The resistor value needs to be as low as possible, but it's minimum value is limited by the typical 25mA max. output current of the FIFO reclocker. |
#4790 | |
