Building the ultimate NOS DAC using TDA1541A
Old 6th March 2013, 10:54 AM   #4751
jstang is offline jstang  United States
I was having the same issue, it was a bad divider chip. Once, I repaired it the erronious back ground noise disappeared to zero. On older recordings, I can pick out the actual background noise on the original analog recordings...
I am clocking DEM at 115khz, as I have a 48 bit word from a CD-Pro.
JohnK
Originally Posted by studiostevus View Post
My DEM setup is not great (I still hear some digital noise in low volume passages), so would be looking forward to hear some ideas from others around this. I was quite happy with 176khz DEM frequency, but as mentioned, I have not set it up properly now....
Old 6th March 2013, 12:30 PM   #4752
Actually 132.3k but if I remember correctly.
JohnK
Old 7th March 2013, 08:19 AM   #4753
studiostevus is offline studiostevus  Netherlands
What C value are you using between pin16 and 17? Somewhere around 700pF then, I assume?
TDA1541a-S2 / 6072a / MediaplayerDac -- Michell Gyrodec -- Aikido Preamp -- Pass F5 -- Audio Physic Tempo 2SE -- Yamamura Cabling
Old 7th March 2013, 04:56 PM   #4754
Eldam is offline Eldam  France
Banned
Hi Studiostevus,
As I see you are here, could you tell me please if you fed the clock in your SB receiver with the same value crystal you remove or do you use the more 12,8xxx (Xilinx Chip has tolerance ?)... I'm a little confuse to close my BOM list here !
thanks if you remember that...
Old 7th March 2013, 05:19 PM   #4755
Originally Posted by Eldam View Post
Hi Studiostevus,
No problem,
I removed both crystals from the SB, and injected only the 11mhz clock signal from my dac board. Have a look at how John designed his clock earlier in this thread.
Old 7th March 2013, 05:44 PM   #4756
Banned
Ok, so 11 Mhz (value of the SB) and not the ~12,8 Mhz of John.
The last Clock design with a standalone crystal is not clear for me, the last shematic is the mk8 with 2 crystal use 12,8 Mhz. So I understand you use 11 Mhz for the SB. I believe i understand the two divide flip/flop chip for the TDA1541 BCK feeding. So i have to buy just one crystal of ~11 Mhz for the clock to inject in SB & TDA1541...
Internet is a good thing, we can be in the same pub even if we are far away...
Thank you Studiostevus
Old 7th March 2013, 05:59 PM   #4757
i guess, i have used earlier the mk7, which was 11mhz...
There many clock designs on the web. One thing to take care of is to use buffered output which can drive 2 devices (in our case both the tda reclocker and the SB). John's mk7 is designed to drive 2 devices, namely the tda reclocker and his sd player, and is therefore very useful
Old 7th March 2013, 08:45 PM   #4758
Banned
I didn't know that... for me bufered output & reciever was just for long wires... thank you for that.
I just have a look to my SB, the crystal are in fact ~22 Mhz, so I understand it's possible to "under"-feed a source with ~11, ~12 Mhz , etc. In my mind, it was a cause of jitter.
I assume it's possible too to go with 22Mhz with more divider for the TDA... but I have to copy a shematic if i want hear something... let's go for MK7 if the SB receiver works with it.
Old 9th March 2013, 09:43 AM   #4759
Xpertv is offline Xpertv  Ukraine
Is it necessary to add 2mA to TDA1541 outputs while I\U is provided by OpAmp? (Stock variant like NE5532\LM833) Or this is only for resistor I\U?
Old 10th March 2013, 02:26 PM   #4760
Actually use the old bck divider and level shift circuit to DEM.... Dividing down bck to 132.3k. I am also running 4x linear intorpolation with s1 chips.
Have 48bit word I2S word from a cdpro.
Building the ultimate NOS DAC using TDA1541AHide this!Advertise here!
