| Digital Line Level DACs, Digital Crossovers, Equalizers, etc. |
#4711 | |
With a tube the SNR would kill resolution. One of the quietest tubes is a triode strapped D3A and it has nice gain but even it would have trouble amplifiying a .002mAx10 ohms*0.0015849 LSB = 0.03 micro Volt signal. Probably end up with a 12 bit resolution DAC at best with a 10 ohm I/V resistor. Oleg did some measurements and found that a 33 ohm resistor with the 2mA offset handled as Pedra does was the best compromise for a tube gain. |
#4712 | |
Hi JOSI,
#4713 | |
Hi tessier,
GlassWare Line Stage & Headphone Amplifiers Kits and PCBs Aikido LV |
#4714 |
EC, thanks for answering...
. but what about heating of the chip? what is the temperature of the chip with very low, Riv? Do You have some experiments on that please?
#4715 | |
#4716 |
I tried it. The chip delivers constant current into a short circuit. However I noticed that the chip is rather hot (even during normal load, not just with shorted output). So I glued a copper heatsink on top in order to reduce the surface temperature, reduce vibration (might be woodoo, but costs nothing), and reduce EMC sensitivity. I grounded the heatsink with a piece of wire to DGND.
#4717 | ||
Hi Zoran,
Modern DAC chips are based on CMOS logic, CMOS logic only draws current during switching as stray capacitance needs to be charged / discharged. These chips run much cooler, but the large differences in supply current between steady state and swithing leads to high on-chip switching noise. TDA1541A Typical power dissipation: 700mW TDA1541A Maximum power dissipation 1W Power dissipation doesn't change with load impedance. Quote:
#4718 |
#4719 | |
what would be the bias currents? Possible to avoid the -15V rail? Last edited by marconi118; 1st February 2013 at 03:31 PM. |
#4720 |
Here is.
