| Digital Line Level DACs, Digital Crossovers, Equalizers, etc. |
#4681 | |
Hi, wlowes
I think that at given aspect it is more important to pay attention to DEM capacitor insulation. It is necessary to choose the capacitors with maximum resistance of the insulation, let in the prejudice of the other parameter even. |
#4682 |
Hi, qusp
It is important for correct working of DEM cells low capacitor leakage of at DC. But you talk about electromagnetic hindrances, which are connected with AC. Of course, advisable reduce these hindrances. But here talk about the other. Last edited by SSerg; 26th December 2012 at 10:17 AM. |
#4683 |
is choosing a less facetious title...
no, it is not just connected to AC, it is connected to i2s, a fast analogue signal used to transmit digital, so kinda AC if you want to look at it that way. fast signals without proper layout/grounding = EMC issues. No i'm not talking about 'other' I also wasnt really talking about capacitors, so I really have no idea what you are talking about....
basically, I know what I was saying, either you didnt understand..or you didnt understand.... and about your post...I didnt understand.... Last edited by qusp; 26th December 2012 at 11:30 AM. |
#4684 | |
Hi, qusp
Let's return towards the insulation quality of the DEM capacitor.Why this it is important? Because leakages of DEM capacitors on direct current (on DC) break the exact double difference of bit currents at nearby bits. This brings appearance of distortion at analog signal. |
#4685 |
Serg,
I assume from this that Styrene, Teflon or Propylene capacitors for the DEM oscilator are recommended, yes?
... jh |
#4686 | |
Oh, really? I2S, a fast analogue signal? "Contributing" this kind of feedback seems a bit counterproductive. BTW, no guilt saying that. Just in case you need a bit of background on this new digital stuff, here you go: http://en.wikipedia.org/wiki/I%C2%B2S Last edited by roger57; 27th December 2012 at 03:02 PM. |
#4687 |
haha man how childish can you be....
seems you completely misunderstood the post, but that doesnt surprise me I was replying to wlowes suggestion that by removing the PCB you would lower the leakages and improve the decoupling by reminding that without a low impedance ground/ ground plane, the fast signals would cause other EM related leakages yeah clock wave is sooo digital isnt it? the interpretation is digital, the wave that represents it is not I suggest you go back and hit the books while I make you disappear Last edited by qusp; 27th December 2012 at 03:59 PM. |
#4688 | |
Quote (again) what you wrote..."... it is connected to i2s, a fast analogue signal." Whatever. I guess I'll get back to my childish Grade 2 reading primer to try and wrap my head around sentence structure. |
#4689 | |
Hi, jameshillj
May suit and ceramic capacitors with good insulation and with enough big working voltage (100V, 250 V and more). The ceramic capacitor inductance is small. How see, choice of the type capacitor - not open-and-shut case. Here needs the compromise. |
#4690 | |
Why is it so hard for people to understand that any digital signal transmission is an analog? Its just basic physics. As far as the PCB-less TDA1541, the concept is you build it point to point in three dimensions on a copper ground plane , Thorsten calls it "bug" building. The results are aesthetically ugly and not commercially viable but make a lot of "sense" on a science/engineering level, perfect for DIY This is why you see little innovation/offerings of TDA1541 PCB's other than the silly china offerings, they just don't make a lot of sense any more.
