For PMBFJ620 in the datasheet, interchangebile S and D, that means that internal structure is symmetrical and the device could be used as P jfet too?
Yes, it's symmetrical, almost all J-Fet's are, it's inherent to the way the semiconductor is made:
Some specific ones for Capacitor Microphones and similar purposes cannot be reversed though.
And no, a reversed N-Channel J-Fet is still an N-Channel.
I tried some JFETS in "opposite" direction S-D, D-S and the Idss was almost the same?
Yup.
Thor
(I tried to test, before year or so, J108 (TO-92) version. It was huge Io with G and S connected to ground...
It is rated as MINIMUM Idss = 80mA!
Very good device, very low RdsON 8ohms,
Yes, I have used it mainly as Audio switch where 74HC40XX correctly applied have their capabilities exceeded. Once these were nixed I had to designs a distortion-free mosfet switch for high voltages or use J111/112/113 equivalents which have very high resistance, by comparison.
BUT it does not behave the same way in the simulations as in the real circuit...)
It does, for me. Maybe your model is NDFG?
Thor
Hi all,
Having completed a 801A Moglia preamp, I'd like to comeback to the idea of a TDA15141A based DAC and incorporate it into it. Sorry for not being "ultimate" but I want to try an old-school, minimalistic design for red-book CD: CS8414 feeding TDA1541A 50Hz DEM, passive I/V to 801A. I have a couple of questions to those with a 1st hand experience:
1) I have very good Jensen SUT's but they cannot stand any DC. Will a balanced operation, achieved with Pedja's I2S data split (each 1541A converts one channel, I think one calls it LL/RR) help to cancell the 2mA offset? I went through most of the thread trying to see a definite answer to that but was a bit hard.
2) Don't kill me for that but how important is to have a PCB at all for just the chip + surrounding caps? Say, I want a minimalistic module: the chip, DEM elctrolytic caps, 3-pin regulators, I2S attenuators. How bad would be a point-to-point, 3D assembly on a universal PCB, running different ground rails (DEM, GDND, Power, Output) star-grounded at pin 5?
@tonimxp
FWIW I have used both the Grundig circuit and the 50Hz circuit. IMHO these are the two that sound the best, but I never heard them back to back so I could not recommend one over the other. I now use the 50Hz one. It was more of an evolution than a careful choice.
Hi All
I have a arcam delta blackbox which utilises the tda1541a.
So far I've recapped it and NOSd it with the grundig DEM mod which I really like the sound of.
I tired various modules.
I've also been playing with parallel boards (this is a dual grundig dem parallel board).
My next plan is to use a modern input board which allows Bluetooth, optical, AES, coax etc at 24bit 192khz.
I'm a tda1541a newbie so just been learning as I go along and reading through the threads a bit This wonderful dac chip.
I'm a right in saying that the tda1541a can handle 192khz but needs to be in simultaneous mode? I can't just connect a 192khz 24bit board to the chip can I?
Just found this amazing item on AliExpress. Check it out!
£30.29 16%OFF | SAA7220 TDA1540 /TDA1541 Format Conversion Driver Module NOS/OS Switching 384K/24bit for Raspberry Pi
https://a.aliexpress.com/_EwJEkMt
My next though was to use a format convertor module, but this had led me down a rabbit hole now.
Can I use this module to drive a pair of tda1541a in parallel? Or is it better to use it on balanced mode.
Im trying to keep it simple hahaha.
Many thanks.
Many thanks.
Many thanks for your report@tonimxp
- Digital Line Level
- Building the ultimate NOS DAC using TDA1541A
