Building the ultimate NOS DAC using TDA1541A - Page 463 - diyAudio
Go Back   Home > Forums > Source & Line > Digital Line Level
Old 21st November 2012, 08:30 AM   #4621
SSerg is offline SSerg  Russian Federation
Hi, -ecdesigns-
Originally Posted by -ecdesigns- View Post
I am now using 22KHz (post # 4615).
If DEM generator frequency constitutes 22 kHz, per time of the sample shaping will not happen the interleaving a current passive divisors of the current that is to say will not happen their averaging. Hereunder principle DEM is emasculated and it not works.
Are younot alarmed?
For correct working DEM generator frequency must be multiple 4Fs or close towards this value. In this case at sample shaping will take part all 4 currents of the passive current divider. Frequency of the standard anisochronous generator constitutes approximately 200 kHz that near towards 4Fs=176 kHz.
Old 21st November 2012, 02:35 PM   #4622
Those are the active dividers. You would need exact 4x (or 8x, 16x, ...) DEM frequency if you did not use any external filtering capacitor, so that always 4 (8, ...) steps fall in a sample. Then perfect averaging would happen. But then the ripple would also appear on the output analog signal. In any other case, even at asynchronous DEM, the external capacitor filters the ripple. As long as this filtering is effective, it does not matter how is the DEM frequency related to the sampling frequency.
Not speaking here about on-chip interaction between the two signals, that have practical manufacturing and not theoretical reason, thoroughly explained by John in this thread.
With respect, Laszlo
Old 21st November 2012, 11:39 PM   #4623
Hi Laszlo, & John,
About this filtering, with the DEM freq down to about 44 or 22kHz ....
If there was an extra R-C network added to each external cap (another 2 SMD units) would the increased filtering be of any benefit?
If so, what would the initial trial/estimated values?
Old 22nd November 2012, 12:00 AM   #4624
So much is clear, however, wouldn't you need fDEM of at least 44khz to make sure the averaging is over 4 Dem steps during one word?
In my understanding, fDEM of 22khz gives averaging over 2 steps (inferior averaging compared to a 4 step cycle). As you say, it should not matter if fDEM is not an EXACT multiple (4,8,16) of fWS, as long as it is at least 44khz (so you get averaging over a full 4-step DEM cycle). For example, a 60khz fDEM would cycle through 5.4 steps per word (60/44 = 1.36 DEM cycle, consisting of 4 steps).
Am I Wrong?
TDA1541a-S2 / 6072a / MediaplayerDac -- Michell Gyrodec -- Aikido Preamp -- Pass F5 -- Audio Physic Tempo 2SE -- Yamamura Cabling
Old 22nd November 2012, 08:43 AM   #4625
galeb is offline galeb  Spain
Hi, after so many time.
Why discusing about the DEM?. It's very easy to try it. Just test some different values of capacitor on the DEM.
With a great capacitor, let's say 1 to 2uf, it sounds very fine, more relaxed, but at very low levels, it make strange sound and noise. On the other side, with 10pf for example, it sounds very fine, maybe a little bit less relaxed, but with an incredible low noise at extreme low levels. You can see on the scope the waveforms at pins 16&17 in both cases. Differences are notable.
I imagine that John is trying some thing more, appart of changing the capacitor value, but at the moment, until he doesn't end his tests, he will say nothing.
Kind regards to all.
galeb saleh
Sarte Audio Elite´s technical audio department
Old 22nd November 2012, 11:37 AM   #4626
You have not understood me. I implied passive dividers, which have included in active dividers, in composition of DEM cells.
This untrue.
John is not authority in the area of TDA1541 working. Many his glances are wrong.
Get acquainted with articles of family TDA1540-TDA1541 developers, and a great deal in TDA1541 working is made clear.
Old 22nd November 2012, 12:08 PM   #4627
Here is reference to monograph of the developer.
http://repository.tudelft.nl/assets/uuid:283c827b-7257-461a-9fce-b0c2e3b6f99f/TR-diss-1781.pdf
Old 22nd November 2012, 12:58 PM   #4628
SSErg,
Perhaps you might like to enlighten us with your superior design - you are extremely critical of John's efforts and detailed explanations of his development progress that has made clear many aspects of this particular dac chip's behaviour to us "less technically skilled" people.
Old 22nd November 2012, 01:56 PM   #4629
Am I Wrong?
I think that averaging a given number of DEM samples over an fWS is not the correct view. Rather, we are filtering the ripple (AC content) from the DC of the given bit current.
Old 23rd November 2012, 05:49 AM   #4630
Refer to http://ftp.slivova.info/andro/DAC0/T...ntMatching.pdf
Page 2, "At the output terminals currents will then flow whereby the average values are exactly equal and have a dc value equal to I."
Copyright ©1999-2017 diyAudio
