| Digital Line Level DACs, Digital Crossovers, Equalizers, etc. |
#4571 | |
Thank for so romantic explanation. Probably, you write the poetry. ![]() But speech in post # 4566 went about rumor, about auditory preferences. Gets out that changed the sound ideal? Serg |
#4572 |
SSerg and Berhard have a point: I am also very interested in the differences and similarities between nos roll-off and the effects of the DI dac. Besides, where would humanity be if we could not challenge each other's ideas anymore...?
That being said, i don't think John OWES anyone an explanation. We have come to expect John to be open in sharing his ideas and experiences, and it would be interesting if he could share his experiences in the above aspect also...
-------- TDA1541a-S2 / 6072a / MediaplayerDac -- Michell Gyrodec -- Aikido Preamp -- Pass F5 -- Audio Physic Tempo 2SE -- Yamamura Cabling |
#4573 | ||||
Hi Bernhard,
So I designed my equipment such way that it becomes highly immune to mains interference. Quote:
I attached an oscillogram of a novel jitter blocker I am working on. Upper trace shows the jitter blocker BCK output. Lower trace shows PCM2706 USB receiver jitter (BCK) output before the jitter blocker. The haze around the transient of the lower signal is clearly visible. So based on this measurement I can at least see that jitter has been reduced and I know the jitter blocker is functioning. Now listening tests can be performed to further analyse the exact impact of jitter amplitude / spectrum on familiar high quality recordings. This is a fast ane effective method of examining the exact impact of jitter (spectrum) on perceived sound. |
#4574 | |
Hi SSerg,
I not only rely on my own listening impressions but also on listening impressions of audiophiles. At the beginning of this thread I was focussing on sample amplitude, smooth signals, low THD and so on. This resulted in the DI system that smoothens the NOS DAC output signal. Digital audio systems do not output a continuous signal like analogue sources do. They output a sequence of separate packages (samples) where each package holds a specified amount of energy. This sample energy will produce a specified amount of power (watts) in a load. The exact amount of energy produced by each subsequent sample depends on sample amplitude, sample duration and sample shape. In the ideal case only sample amplitude changes according to sample value while sample duration and sample shape remain exactly the same for all samples. This has resulted in reverting to one DAC chip, placing main focus on sample duration and sample shape. |
#4575 | |
Hi studiostevus,
Unfiltered NOS DAC produces a square wave. Square waves hold highest amount of energy (form factor 1) Filtered NOS DAC produces a sine wave that holds less energy: 1 / SQRT(2). DI DAC produces a triangle wave that holds lowest energy: 1 / SQRT(3). http://en.wikipedia.org/wiki/Form_factor_(electronics) Suppose an unfiltered NOS DAC with a square wave output of 1Vpp would produce 1 mW in a specified load. Filtered NOS DAC with a sine wave output of 1Vpp would produce 0.707 mW in that same load. DI DAC with a triangle wave output of 1Vpp would produce 0.557 mW in that same load. So unfiltered NOS DAC produces highest energy @ 20 KHz and thus causes lowest trebles roll-off. Filtered NOS DAC comes next with higher trebles roll-off. DI DAC causes highest trebles roll-off. I have been using unfiltered NOS DACs for quite a while, these offer lowest trebles roll-off. One can apply trebles boost filters for flattening the frequency response. If I am correct trebles boost is also applied in digital brickwall filters. This however conflicts with the statement I made in previous post (wave form of each sample must remain exactly the same). |
#4576 | |||
I wrote:
Pardon me if I can not find every one of quotes, the thread is very long. Here is one: #1612 Quote:
#4577 | |||
I wrote:
Are you sure ? #4548 Quote:
#4578 |
Bernhard, maybe this was just a statement of "look, this is how the a pure sine wave with very low distortion looks on my scope"
The missing link between lead and gold in alchemist's world was BS and commerce. |
#4579 | |
can you post a schematic of some simple circuit that achieves this treble boost for an unfiltered NOS tda1541a Dac ? I would be very happy if I would be able to test such a filter so I could drop the parametric EQ in my setup that stands right before the power amp just for this purpose; I am using a parametric EQ over a graphic EQ because I can achieve a higher Q slope in compensating high frequency roll-off. Thanks!
== NIHIL SINE DEO - Nothing Without GOD == |
#4580 |
Try to incorporate that EQ into lowpass reconstruction filter by rising it's Q.
