| Digital Line Level DACs, Digital Crossovers, Equalizers, etc. |
#4561 | |
![]() Why don't you have a look at the TDA1541A specs. I think it's 2's comp device, so you should be able to push clock, latch and data signals straight in, if timing diagrams show they are the same. |
#4562 |
roger57, TDA1541 is not a 2's complement like PCM63 is. IIRC, TDA1541 is offset binary. Just looking for a real-life implementation of I2S to 2's complement from someone who's "been there, done that"
#4563 | |
Hi Phisci,
Cs8412 - Pcm63 Non-oversampling |
#4564 |
Hi Phisci,
I2S is 2's complement. TDA1541A can accept both 2's complement and offset binary. PCM63 accept only 2's complement. There is no problem. Sorry for off-topic, everyone. |
#4565 |
Thanks for the input guys
#4566 |
#4567 |
Dear SSerg,
I don't think your last post contributes to anything at all... Sincerelly yours, M.
"Thou shall build big horn speakers" |
#4568 | |
why don't you use a spectrum analyzer ? How can you visually inspect a sinewave on a scope and claim it has - very low - distortion ? Same with your 2,5 kHz problem. Why not make a scan 20 Hz to 20 kHz ? It will tell everything. Not so long ago, - extremely low - jitter proved with 60 MHz Hameg... Many other things I can not understand, one example, you dropped the DI because hf roll off. But what about the nonos hf roll off ? |
#4569 | |
I don't at all try to poke fun at author of the thread – in no event. On the contrary, many EC ideas are close to me. I just try to understand at evolutions of his preferences, at dignities and defects his design. Sincerely yours, Serg |
#4570 | |
I think -EC- has explained each and every step he has chosen. Beside, change in opinion in front of new experiences is sign of a healthy mind. I'm sure we all had an old love that seemed the nec-plus-ultra of beauty and other desirable traits, until a new beloved one de-throned her...
