Building the ultimate NOS DAC using TDA1541A - Page 41 - diyAudio
Go Back   Home > Forums > Source & Line > Digital Line Level
Old 22nd June 2006, 04:47 AM   #401
Hi maxlorenz,
No, I'm not angry [post#375]
I just wanted to indicate the errors produced by NOS-DAC's and the octal D-I DAC are present, but wanted to put them into perspective. By over-emphasizing problems there is no point in designing anything as nothing will ever be perfect enough. One theory fill follow the other, with the end result a NO-DAC.
I will take your wise advice,
As far as I am concerned, the octal D-I DAC also transmits the soul of music. In my humble opinion this is mainly caused by both phase linearity and harmonic balancing using the mixed mode. The Direct Interpolation reduces harmonics amplitude when compared to the standard NOS-DAC. I already invited one DIYaudio member for a listening session.
Resting from time to time is very difficult for me, I have been working for over 15 years now without a holliday. Guess that makes me kind of a workaholic .
Old 22nd June 2006, 08:19 AM   #402
Default Some octal D-I DAC oscillograms
Hi all,
I added some oscillograms that show comparison between signals generated by a standard NOS-DAC and octal D-I DAC, both DAC's get the same SPDIF input signal, this might put things in perspective. Oscillograms also show both DAC output signals run nicely in phase.
Photo top left, shows how the octal D-I DAC smoothes a course stepped sinewave
Photo top right, shows what is still recovered with very few steps.
Photo bottom left, shows a 500Hz sinewave greatly magnified, notice the gained resolution
Photo bottom right, shows a 1 KHz squarewave, notice the flat responce and the steps on the transient
So the squarewave shaped signals with mainly odd harmonics, are converted to a more sawtooth / triangle shaped signal with more even harmonics. Soundwise even harmonic distortion has a less negative effect on sound quality then odd harmonic distortion.
The major harmonics are caused by the difference between a pure sinewave and the stepped approximation. The harmonics amplitude is in relation with the amplitude of the error signal. By generating smoother stepped sinewave signals, the amplitude of the error signal drops accordingly. The harmonics are still there, but their amplitude has been lowered. By the higher virtual sample frequency, harmonics are shifted up the spectrum, so interference in the audio spectrum is reduced
One could use a (Bessel) filter to attenuate these residual harmonics, if desired, they are already attenuated by bandwith limiting in the amplifier
Old 22nd June 2006, 10:46 AM   #403
Bernhard's Avatar
Originally posted by poobah
I
the graph would not post here well.
Do you think it would hurt anybody ?
Old 22nd June 2006, 11:00 AM   #404
Bernhard's Avatar
About the possible reduction of nonlinearity:
I did not look at the schematics but if it is linear interpolation of 8 DACs, it should be at the start of a new original sample:
1 DAC carries current of new sample & 7 DACs carry current of previous sample -> 2 DACs carry current of new sample & 6 DACs carry current of previous sample -> 3 DACs carry current of new sample & 5 DACs carry current of previous sample -> 4 DACs carry current of new sample & 4 DACs carry current of previous sample -> 5 DACs carry current of new sample & 3 DACs carry current of previous sample -> 6 DACs carry current of new sample & 2 DACs carry current of previous sample -> 7 DACs carry current of new sample & 1 DAC carries current of previous sample -> 8 DACs carry current of new sample & 0 DACs carry current of previous sample -> starts next original sample...
So there are 8 different combinations of paralleled DACs inside one original sample.
That could be even more beneficial than just paralleling.
Please correct me if I'm wrong.
Old 22nd June 2006, 11:01 AM   #405
I think so ...
Old 22nd June 2006, 11:23 AM   #406
Bernhard's Avatar
Originally posted by rfbrw
...we don't want no no-sayers here in town.
And no clueless photographers either.
Nice to hear that you share my opinion about the notorious no-sayers
Any clueless photographers around ?
Old 22nd June 2006, 01:06 PM   #407
You are wrong. All samples are 'original' and nothing is in parallel.
Old 22nd June 2006, 01:11 PM   #408
Can't say I do, not that it matters much. You'll talk a lot and measure a lot but it will be a cold day in hell when you actually make anything.
Old 22nd June 2006, 02:27 PM   #409
Bernhard's Avatar
Ok, samples are original, but only on the digital side.
The DACs get them with different delays.
The delays are < one sample so the samples overlap and that is where the DACs are parallel.
On the analog side x DAC-currents from a previous sample are added to y DAC-currents from the next sample, and the I/V does see it as a new & wrong sample.
Your post #408 is not worth a reply.
Old 22nd June 2006, 03:19 PM   #410
I agree with Bernhard, a DACs output is held until the next sample value is reproduced. So all the DAC outputs, at any given time, will be providing a current - so they are all summed as they are connected in parallel.
rfbrw, I think you are unreasonable to comment like you did. I am incredibly distracted, and I rarely make much kit at the moment. Everybody's commitments and distractions elsewhere in life impact this. I envy you as you obviously have more time than I (and perhaps Bernhard) to craft things. However, there is nothing wrong at all with theoretical discussion, and sensible measurement. They have their places.
This is a great thread. Please, lets not spoil it!
Phil
Copyright 1999-2017 diyAudio
