| Digital Line Level DACs, Digital Crossovers, Equalizers, etc. |
#4021 | ||
Previously: Kuei Yang Wang
Location: Somewhere nice on planet earth where censorship of Ideas is frowned upon
![]() I had actually typed a longer comment on this but the dog ate it. ![]() Ciao T |
#4022 | |
is choosing a less facetious title...
#4023 | |
I wasn't reffering to you personally sorry you took it that way. I was just saying to look around for an authentic TDA1541 they are very attainable no need for fear mongering. The K rated PCM56 which is the grade to sensibly considered has been discontinued, for all PCM56 it says right on ti website "NRND: This product is not recommended for new designs. However, the device, tool, or software continues to be in production to support existing customers. TI does not recommend using this part in a new design. TI encourages designers to consider alternative products for new designs." That means its done, mouser and digikey no longer sell the PCM56k. The idea you dropped that all TDA1541x's available are becoming counterfeit or unattainable is absolutely absurd. Thread Police? is this not a TDA5141 thread, please lets move on and no need for personal attacks. |
#4024 | |
#4025 | |
No, I don't think the linear-phase offset of the 11uS delay is consequential for headphones, where the whole listening experience is devoid of a natural image perspective anyhow, pleasurable as it may be in it's artificiality. In addition, as Thorsten points out, correcting the delay is a trivial matter in terms of the logic gates required. Apology accepted. I did no such thing as to suggest all TDA1541A are becoming counterfeit. What I did was open the issue of the increasing scarcity, not impossibility, of obtaining devices. The notion that the availability of a chip last manufactured nearly 20 years ago, and what John Brown sees as the next best alternative, is somehow off topic seems an oddly myopic view. Yes, I couldn't agree more about the personal attacks. May I suggest that you refrain from initiating them in the future.
Ken Last edited by Ken Newton; 25th November 2011 at 06:05 PM. |
#4026 | |
Ken Last edited by Ken Newton; 25th November 2011 at 06:04 PM. |
#4027 | |
TBH, personally I would probably do a hybrid DAC, not dissimilar to the Ultra Analog stuff, with a discrete DAC in an FPGA plus suitable bitswitches and reference sources for the upper maybe 8 Bits and an integrated DAC like that TI DAC8580 for the lower maybe 16 Bits (and no, I see absolutely no point in 32 bit DAC's). Ciao T |
#4028 | |
Hi FRUGIVO,
Try to keep ALL connections as short as possible, every millimeter really counts. The resistive attenuators (4K7 and 2K2) only work reliably with very short interlinks between attenuator and DAC chip (capacitive loading). Mount all circuits on a ground plane like the copper side of a piece of PCB material. Try to keep incoming I2S signals well separated (crosstalk), you could use flat cable with following arrangement: GND, DATA, GND, WS, GND, BCK, GND Datasheet DEM clock configuration leads to low performance due to inter-modulating clocks (on-chip crosstalk) between free running DEM clock and I2S timing signals. It's better to synchronize the DEM clock with BCK (2.8224 MHz) when using NOS. The DEM clock can also be synchronized on multiples of WS when fine tuning the value of the external timing cap. Locking can be checked using an oscilloscope. Keep in mind that this type of synchronization is instable and locking can be lost with varying chip temperature. I stopped using ceramic SMD caps a while ago after I experienced problems with reliability and performance. I now use SMD film caps exclusively. |
#4029 | |
If I understand correctly, the common-mode regs posted in 3978 have now been replaced by the ones in the main schematics plus the ones in the main power supply of the dac? Also, I thought you were using air-coil inductors... now I see a center-tap connected to GND? Last edited by studiostevus; 26th November 2011 at 08:20 AM. |
#4030 |
why is that? 32 bits used for just audio, i agree with you, but 32 bit dac chips allow filters, volume etc to be calculated with far better accuracy and be more 'out of the way'
