Building the ultimate NOS DAC using TDA1541A - Page 400 - diyAudio
Go Back   Home > Forums > Source & Line > Digital Line Level
Old 18th November 2011, 08:51 AM   #3991
brubeck is offline brubeck  Netherlands
Originally Posted by -ecdesigns- View Post
Here is a screen shot of the new TDA1541A-MK8 module PCB lay-out
It looks like it fits in a cd-player. Nice sentiment..
Old 18th November 2011, 08:58 AM   #3992
qusp is offline qusp  Australia
qusp's Avatar
Originally Posted by brubeck View Post
I can add to this that we recently did a A/B listening comparison with my own full battery driven (4 x lead/acid) MK7 with discrete regulators against a same MK7 module with a experimental alpha version of the common mode voltage regulators on mains power. We did this test at John's place where the mains is pretty dirty. We could here NOT ANY DIFFERENCE between the batterie system and the mains PSU, how hard we tried. Incredible, a novum imo.
you should try some truly low noise batteries, lead acid isnt exactly the leading edge of battery chemistries for audio. thats not a comment on the regulator design, which looks very interesting indeed and i'll definitely give it a try when more details are published. it could make for a nice alternative to batteries for the floating supplies for the CEN/SEN jfet IV stage by EUVL
Old 18th November 2011, 06:12 PM   #3993
I was thinking the same. Let me know your results!
TDA1541a-S2 / 6072a / MediaplayerDac -- Michell Gyrodec -- Aikido Preamp -- Pass F5 -- Audio Physic Tempo 2SE -- Yamamura Cabling
Old 18th November 2011, 07:14 PM   #3994
qusp's Avatar
will do, it appears as though the darlingtons are end of supply at digikey, so adding some to my order now, i cant guaranty when i will get around to them though as i will be primarily focussing on batteries, but i WILL try them, dont really need any more detail either, cheap and simple to knock up and i think ive even got suitable zeners.
@ John, can buried zeners or other forms of reference be used for lower noise? i guess there is some reason you chose straight zeners though, no feedback perhaps?
Old 19th November 2011, 08:22 PM   #3995
In the I2S attenuators, the diodes were replaced by a resistor. Resistor values were increased in order to reduce RF energy being dumped on the chip substrate. This allowed me to re-install the decoupling caps for WS and BCK reclockers.
BCK, Q: 100R, /Q: 470R, power supply series resistor: 470R, decoupling 1uF SMD film.
WS/DATA, Q: 470R, /Q: 2K2, power supply series resistor: 1K5, decoupling 1uF SMD film.
DEM injection: 2K2 / 12K
Masterclock: 100R with 1uF film bypass connected between GND and both chokes. This lifts the clock signal above GND and makes the clock rectifiers obsolete. The masterclock now runs on 2V power supply (4V minus 2V reference).
So, for bck, d5 and d6 are replaced by a 470r resistor, and 2k2 is added on the /q line... What are the resulting ttl levels?
Also, i remember i asked earlier why each flipflop was not decoupled separately. It seems in the current solution, they are? Or is it decoupling of the bck/ws/data lines themselves?
Old 19th November 2011, 10:22 PM   #3996
Hi brubeck,
I attached some pictures of the TDA1541A-MK8 module that was completed today.
Old 19th November 2011, 10:42 PM   #3997
qusp's Avatar
nice one, ive been using those panasonic pps for a while now too, very nice caps. cool looking module for sure; i pictured you using bulk foil trimmers =)
Old 20th November 2011, 09:22 AM   #3998
JOSI1 is offline JOSI1  Germany
Hi John,
thank you for posting the schematics of the latest regulators and some pictures of the MK8 module.
In your designs you are using MELF resistors. Do these resistors have an electrical advantage compared to 0805/1210 or is it just for easier/better mounting and soldering?
Old 21st November 2011, 02:53 AM   #3999
qusp's Avatar
well they are metal foil resistors, rather than regular thin film, but i thought i read that they were magnetic
Old 21st November 2011, 06:26 AM   #4000
Hi studiostevus,
So are there still a lot of caps in front of the regulators?
5 capacitors for each supply voltage, one smoothing cap and 4 more in the common mode capacitance multiplier. The power supply for the SD-player will have 5 isolated supply voltages, 4 for the DAC module and 1 for the SD-transport.
With the prototype setup I use 3 mains transformers, two transformers with 2 x 12V and one with 2 x 18V. Each common mode capacitance multiplier is connected to a separate transformer winding so all power supplies are "floating". The masterclock power supply is derived from a 18V winding using a couple of 100 Ohm resistors between transformer and rectifier in order to get required voltage on the common mode capacitance multiplier.
Transformer #1 is used for TDA1541A +5V and -5V supply. Transformer #2 is used for TDA1541A -15V and +5V masterclock supply. Transformer #3 is used for 3.3V SD-transport supply.
With these values low = 0.42V, high = 1.98V. I am currently experimenting with different values to further reduce RF energy. MK8 module now has 2K2 and 4K7 installed. This results in low = 0.7V, high = 1.5V.
The MK8 has 1uF SMD film power supply decoupling caps on all flip-flops. This is possible because of the modified I2S attenuator circuit.
Copyright 1999-2017 diyAudio
