Building the ultimate NOS DAC using TDA1541A
Old 13th November 2011, 04:34 PM   #3981
studiostevus is offline studiostevus  Netherlands
Originally Posted by -ecdesigns- View Post
Hi JOSI1,
I attached common mode regulator concept schematics for both, a positive and negative 5V supply.
John, can you share listening impressions of your voltage regs compared to other discrete alternatives?
I am designing a pcb now, based on many of your concepts, but with salas shunt regulators (most importantly to also add something of 'myself' and not to copy your whole design...). Not sure if i should pursue the salas regs or move towards your latest solution....
TDA1541a-S2 / 6072a / MediaplayerDac -- Michell Gyrodec -- Aikido Preamp -- Pass F5 -- Audio Physic Tempo 2SE -- Yamamura Cabling
Old 13th November 2011, 04:58 PM   #3982
Joshua_G is offline Joshua_G  Israel
Joshua_G's Avatar
As far as I can see, John's Common Mode Regulator isolates both voltage supply and ground between the transformer/rectifier and the load.
Salas offers shunt regulator, which serves (probably successfully) a different purpose, which is supplying a very quiet voltage, but there is no isolation of the ground.
Possibly, a combination of both will be as good as it can be (especially for analog circuits).
However, when it comes to digital circuits, there is a huge benefit in isolating the power supply to each of the elements (clock, frequency divider, DAC chip, etc'). So, one shunt regulator to the entire unit may not be the best solution. Probably, a capacitance multiplier, or a separate regulator, to each of those building blocks is the best approach, since it does both functions in one stroke: supplying a very clean voltage and isolating different building blocks from one another.
Old 15th November 2011, 02:25 PM   #3983
marconi118 is offline marconi118  United Kingdom
is the FET regulator of MK7 on post 3681 now obsolete?
Old 17th November 2011, 06:25 AM   #3984
ecdesigns is offline ecdesigns  Netherlands
Hi studiostevus,
The common mode voltage regulators result in a sound quality that closely approximates vinyl (without the scratches) and studio tape. With the discrete voltage regulators sound is already very good but one can still hear that the sound originates from a digital audio playback system.
The cascaded filtered buffered zener regulators in the form of a common mode regulator offer very fast local feedback and very low noise. They also provide essential high impedance between transformer / rectifier and connected load by placing a high impedance in the ground lead.
Old 17th November 2011, 06:34 AM   #3985
Hi marconi118,
Yes, the new TDA1541A-MK8 will have 4 on-board common-mode regulators based on the filtered buffered zener regulator concept.
Old 17th November 2011, 09:06 PM   #3986
brubeck is offline brubeck  Netherlands
Hi studiostevus,
I can add to this that we recently did a A/B listening comparison with my own full battery driven (4 x lead/acid) MK7 with discrete regulators against a same MK7 module with a experimental alpha version of the common mode voltage regulators on mains power. We did this test at John's place where the mains is pretty dirty. We could here NOT ANY DIFFERENCE between the batterie system and the mains PSU, how hard we tried. Incredible, a novum imo.
Old 17th November 2011, 10:14 PM   #3987
Joshua_G's Avatar
Applauds to John.
Old 18th November 2011, 05:14 AM   #3988
So are there still a lot of caps in front of the regulators?
Old 18th November 2011, 08:16 AM   #3989
Default TDA1541A-MK8 PCB lay-out
Here is a screen shot of the new TDA1541A-MK8 module PCB lay-out
Old 18th November 2011, 08:34 AM   #3990
Looks very optimized! Mine is a lot more spaghetti in the reclocker.
What is the bit on the right of the reclocker (with the wirewound R) ?
Building the ultimate NOS DAC using TDA1541AHide this!Advertise here!
Copyright ©1999-2017 diyAudio
