Building the ultimate NOS DAC using TDA1541A
Old 24th February 2011, 09:11 AM   #3611
marconi118 is offline marconi118  Germany
This is really GREAT!
maybe an improovement idea:
use optpcouplers on the 3 I2S signal imput to isolate the ground of the transport device (I will use the I2S outpout of a ENVY PCI sound card chip)
Old 24th February 2011, 12:48 PM   #3612
Ken Newton is offline Ken Newton  United States
Ken Newton's Avatar
Originally Posted by -ecdesigns- View Post
Hi luxury54,
There is approx. 4V DC on each I/V resistor. So I simply used a 1K potentiometer and suitable decoupling cap to create an adjustable reference voltage. There is a separate reference voltage for L and R channel. This reference voltage now serves as "GND" reference for connected equipment.
By trimming each voltage so it exactly matches DC voltage on the I/V resistor, the DC voltage between I/V resistor and reference becomes zero. In other words, the DC component is removed without using a coupling cap.
The circuit is kept very simple, 1K multiturn trimmer. One side goes to GND, the other to +5V. Suitable decoupling cap is connected between wiper (minus) and +5V (plus). The adjustable reference voltage is now on the wiper.
Hi John,
I once considered such a solution for eliminating the output coupling cap. There are two issues, one minor and one not so minor, that I found.
First, a 'rail-splitting' resistive divider network will substantively increase the circuit output impedance. That's probably a minor concern in a low-level output application. The not so minor concern is that separate left and right offset zero'ing trimmers will be shorted together at the common left and right channel ground of any following amp or preamp input circuit - unless that input is floating or transformer-coupled. This common signal ground connection would equalize the voltage back at the two trimmer wipers inside the DAC, re-creating a D.C. offset there. One can't utilize a common resistive divider to create a single ground reference because the additional impedance on the ground return would be modulated by each channel's signal return current, effectively producing a particularly severe ground-loop.
How did you resolve such issues in your design?
Old 25th February 2011, 08:55 AM   #3613
ecdesigns is offline ecdesigns  Netherlands
Hi Ken Newton,
The trimmer value equals 1K, when adjusted for 4V DC there will be approx. 200 Ohms between +5V (where the I/V resistor connects) and reference voltage. For ac signals the remaining 800 Ohms will be in parallel (impedance between GND and +5V is almost zero). So added impedance will be 160 Ohms, this increases total output impedance to only 660 Ohms.
I could also use trimmers with lower resistance, 250 Ohm for example. Then the output impedance would only increase from 500 to 540 Ohms.
But since I use 470uF decoupling caps in parallel with this 160 Ohms, increase in output impedance is negligible.
I tested many different semiconductor and tube unity gain buffers to lower output impedance, but the distortion, noise, and loss of (time) resolution doesn't justify their use.
The reason this is so critical is that huge amount of information is left out in digital recordings. Analogue signals have almost infinite bit depth and and infinite sample rate, then one can afford some (time) distortion before perceived sound quality starts to degrade. In other words, when using analogue sources, playback equipment is far less critical as with digital sources.
Suppose we made an approximation by using say 1GHz sample rate and 24 bit resolution. Then we would require 21.6 Terra bytes of information for a 1 hour stereo recording. It would even be doubtful if this information could even be stored and retrieved fast enough for a real-time audio stream.
This still would offer lower resolution compared to the original analogue source. With 44.1/16 we only have 635 Mega bytes at our disposal for 1 hour of music. This should give an impression of the amount of information that was left out.
Digital playback systems can restore fundamentals within the audio spectrum, but they offer very limited time resolution as samples can only change at 22.6us intervals (44.1/16) or 5.1us intervals (192/24).
Practical example, some instruments produce fundamentals that are time shifted at say 11.34223us, 1.02234us, 125.4ns, 881.3442ns and 201.33us.
Digital playback system (44.1/16) would have to force-fit these harmonics into multiples of 22.6 us. So 11.34223us, 1.02234us, 125.4ns, and 881.3442ns translate to zero. Finally 201.33us translates to 181us or 204.084us.
So the playback equipment should be optimized for the time domain in order to preserve whatever time resolution remains after the A/D conversion process. Higher time resolution doesn't result in a day and night difference in perceived sound quality, it does however add more refinement, making the music more realistic.
Since both are decoupled with 470uF, crosstalk between the channels will be remain low. There might be a small DC offset increase that is acceptable in most cases. The DC offset increase depends on channel matching.
I made sure the channels match very closely.
Split reference was maintained throughout my audio set using separate shunt volume controls and Circlotron monoblocks.
Old 25th February 2011, 03:59 PM   #3614
dirtbiker1824 is offline dirtbiker1824
Is there any chance you could post a schematic of the MOSFET amplifier circuit? I'm trying to build a small 40 watt/channel amp using the TDA7376B chip but it's quality is not that great. I'd also like to send it optical signals and I'm unsure how to conver the optical signal to line level audio, any advice?
Thank you
Old 28th February 2011, 06:30 AM   #3615
Hi dirtbiker1824
I already did, photograph of the single-PCB Circlotron power amp is in post #3528
Concept schematics are in post #3539. In the final version a number of modifications were made like using discrete voltage regulators, Honeycomb Mobius wire wound resistors and Honeycomb Mobius purifiers.
This chip was designed for car audio applications, not for high-end audio.
This involves signal conversions that are likely to cause further degrading.
Old 1st March 2011, 02:20 PM   #3616
maxlorenz is offline maxlorenz  Chile
maxlorenz's Avatar
Default OT; sort of...
Hi dear -EC-
Since last year I have neglected DIY (but followed your threads) due to job and to my new (and expensive) hobby of playing/enjoying/collecting violins.
My luthier lend me some Dammar gum and I applied as a varnish, diluted on turpentine, on my Audio Nirvana fulrange drivers. I had not listened to them yet. I want them to dry a little more.
With the dammar varnish left I thought about emulating "tube-O-lator":
The Altmann "Tube-o-lator" lacquer
so I put on it powdered graphite from cheap pencils until getting a dark grey matter that I applied to the inexpensive TDA1543 chip, only on the "roof" (I will later put it all around) and waited. Am I getting crazy or the sound changed?
Anybody has experience with this?
Cheers.
M.
Old 1st March 2011, 02:44 PM   #3617
Bernhard is offline Bernhard  Germany
Bernhard's Avatar
A much better and well proofed solution is angel dust scattered all over the pcb.
Old 1st March 2011, 02:44 PM   #3618
QSerraTico_Tico is offline QSerraTico_Tico  Europe
QSerraTico_Tico's Avatar
Talking Come on!
Hi dear -EC-
Cheers.
M.
K-Y Gelly? Come on!
Old 1st March 2011, 04:36 PM   #3619
maxlorenz's Avatar
Hi dear,
"Hoc Non Pereo Habebo Fortior Me"
Anybody here knows the meaning of experimentation?
Old 1st March 2011, 07:49 PM   #3620
Sandor is offline Sandor  Italy
Hello John,
how does your circlotron amp perform with loads as low as 2 ohms?
Building the ultimate NOS DAC using TDA1541AHide this!Advertise here!
