Go Back   Home > Forums > Source & Line > Digital Line Level
Old 16th February 2011, 01:59 PM   #3601
Hi John,
looks like the MK6 DAC is almost complete. What is the cost + availability for the DAC module? I have 3x 12V SLA batteries for the PS, can I power the DAC directly from the +12,-12 and -24V rails on the connected batteries?
looking to connect my Squeezebox Duet I2S connections directly to the DAC - please can you advise on a suitable method of taking the clock from the DAC so that I can also try slaving the 11.286 clock on the squeezebox.
I also have one of your SPDIF tracker receivers that I would like to use with the DAC - could I set up the tracker to feed I2S directly into the new DAC, so that I get the full benefit of the new reclocking and attenuation on the MK6?
cheers
Brad
Old 17th February 2011, 08:12 AM   #3602
fff0 is offline fff0  Singapore
Originally Posted by Builder Brad View Post
Hi John,
looks like the MK6 DAC is almost complete. What is the cost + availability for the DAC module?.........
I am too very curious to know.
Old 17th February 2011, 11:01 AM   #3603
fvale is offline fvale  Italy
Update, should someone be interested. To reclock WS (it's LE, latch enable, more correcly with these SAA7000/TDA1540) I had to use MCK. I don't understand the reason why with the reclocked BCK I don't get any output from the 74 reclocker.
Old 22nd February 2011, 08:53 AM   #3604
-ecdesigns-'s Avatar
Hi phi,
If you by 'Charge compensation' mean 'damper', a resistor i parallell with the capacitor that dampens high frequency ringing, then I follow you...
The bypass resistor values are rather high, approx. 30 M Ohm for a coupling cap, 10K ... 100K for a power supply decoupling cap and approx. 22 K Ohm for speaker crossover filter caps.
The values seem to be too high to effectively dampen high frequency ringing.
I now run my set fully DC-coupled, using a passive adjustable DC bias circuit for each channel. Volume control is passive, based on non-inductive wire wound resistors, and the power amps are also fully DC-coupled.
Coupling caps always add more distortion, noise and coloration compared to a short piece of wire.
The coloration and distortion of a coupling cap can in some cases result in an initial "wow" effect. But after listening for longer time periods, also using different types of music, the "extra" information added by the capacitor can become annoying.
This basically means that every added coupling cap reduces the chance of ever achieving ultimate performance.
Old 23rd February 2011, 10:25 AM   #3605
Default I/V resistor value
Noob question:
I have always read that the I/V resistor for TDA1541 should be less than 100Ohm to limit the distortion.
In MK6 you use 500Ohm to have higher mV output. Is this leading to distortion?
Did I miss something?
Old 23rd February 2011, 12:27 PM   #3606
100 ohm was the value used by the "lampizator" man when a SRPP tube stage followed right after the TDA1541A's output;
and indeed, when I also experimented with his setup 100 ohm was the best value/compromise to use there;
but this stage designed by EC it's a complete different workaround
Old 23rd February 2011, 03:04 PM   #3607
is it possible to avoid the volume pot and regulate the volume by changing the 500Ohm I/V value?
Changing the I/V resistor value, is it needed to recalibrate the pot on the mosfet gate?
Old 23rd February 2011, 08:19 PM   #3608
Hi marconi118
TDA1541A output compliance equals +25 / -25mV. Output sinks a constant current from output to -15V that varies between zero and 4mA. It sinks 2mA when no signal is applied (bias current).
When the passive I/V resistor is connected between GND and DAC output a voltage will develop across it as current varies.
The theoretical max. I/V resistor value (I/V resistor tied to GND, so voltage can only go negative) equals R = v / imax. R = 0.025 / 0.004 = 6.25 Ohm. So the indicated value of 100 Ohm is already 16 times too high, distortion will be accordingly. Things can be improved a bit by positioning the ac signal around GND, this requires an additional bias voltage for the passive I/V resistor. However it is extremely difficult to create required ultra low noise reference voltage.
The resulting distortion is caused by the diode transistor bit switches inside the DAC chip that have saturation voltage of approx. 0.6V. The higher the voltage at the DAC output, the more this voltage gets into the non-linear region of the diode characteristic thus causing more distortion until clipping occurs.
I did not connect the passive I/V resistor between DAC output and GND. I connected a grounded-gate buffer between DAC output and passive I/V resistor. The grounded-gate buffer is built around a lateral power MOSFET that basically passes the DAC output current to the passive I/V resistor while maintaining low impedance on the DAC output.
This buffer has low input impedance (approx. 12 Ohms) and high output impedance. There is no output compliance at the buffer output, it could theoretically generate large voltages across a passive I/V resistor. When using 10K I/V resistor (and high enough voltage to feed the I/V resistor) voltage of 0.004 * 10,000 = 40Vpp could be generated while still meeting DAC output compliance.
This offers the unique situation of generating sufficient voltage across a passive I/V resistor without the need for extra amplification or buffering. When using very high performance resistors for passive I/V conversion, noise levels are extremely low, this results in a pitch black background. No tube nor semiconductor output stage could come anywhere close. This configuration also offers highest resolution and lowest sound coloration.
Yes, re-calibration is required when changing I/V resistor value, changing I/V resistor supply voltage or changing DAC chip (tolerances).
Since DC voltage is generated across the passive I/V resistor, 1V when using 500R, varying I/V resistor value will cause large temporary DC shifts on the output. The DC calibration at the DAC outputs also varies as I/V resistor value is varied between o and 100 Ohms. It would also become problematic to get I/V resistor value low enough for achieving very low volume levels.
I use a binary controlled shunt regulator based on high performance non-inductive wire wound resistors for maintaining extreme low noise levels and maximum resolution.
I also applied full DC-coupling using passive adjustable reference voltage for each channel. So the distortion and coloration of the coupling cap is fully eliminated.
In the MK6 the 4mA full scale current will generate 0.004 * 500 = 2Vpp amplitude directly across the passive I/V resistor. The output impedance equals 500 Ohms.
Since I meet TDA1541A output compliance (12 Ohm load), and voltage swing is centered around 0V DC, distortion is close to the values specified in the datasheet.
Old 24th February 2011, 04:50 AM   #3609
Hi EC,
I'm very curious how you got rid of that necessary evil - the coupling cap and it's colorations;
maybe later on you'll be able to show us some simple schematics for us to try your wonderful inovations
Old 24th February 2011, 07:48 AM   #3610
Hi luxury54,
There is approx. 4V DC on each I/V resistor. So I simply used a 1K potentiometer and suitable decoupling cap to create an adjustable reference voltage. There is a separate reference voltage for L and R channel. This reference voltage now serves as "GND" reference for connected equipment.
By trimming each voltage so it exactly matches DC voltage on the I/V resistor, the DC voltage between I/V resistor and reference becomes zero. In other words, the DC component is removed without using a coupling cap.
The circuit is kept very simple, 1K multiturn trimmer. One side goes to GND, the other to +5V. Suitable decoupling cap is connected between wiper (minus) and +5V (plus). The adjustable reference voltage is now on the wiper.
I tried many semiconductor-based references like buffered bandgap references, diode references, OP-amp based DC servos and so on. As soon as a single semiconductor was used, performance immediately degraded. This was very audible with the double crown chip. I am currently using 1K 15ppm bulk metal foil trimmers and a 470uF/16V Sanyo Oscon decoupling caps.
I added a picture of this DC reference module. The two Mobius Honeycomb loops are in the signal path and are used to further purify the signal. This is done by running it through a 2 meter long thin solid-core OFC copper wire. The Honeycomb Mobius structure ensures the piece of wire remains non-inductive and compact. The idea is to improve flow properties of electrical charge.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright ©1999-2013 diyAudio
