| Digital Line Level DACs, Digital Crossovers, Equalizers, etc. |
#3501 | |||
Hi ernesternest,
Problem is that the output stage has very large bandwidth (theoretically up to FET Ft). This is a property of the grounded gate buffer. FET input capacitance (approx. 30pF for 2SK170) is placed in parallel with FET current buffer input impedance of around 12 ... 40 Ohms. The result is that the FET is always operated close to its maximum frequency and thus introduces distortion and causes instability. This can lead to audible distortion, and that's basically the flaw that was in all of the current buffer circuits I used. When using slower (lower bandwidth) output circuits like OP-amps or discrete OP-amps, the problem also occurs. Possible solution is placing a suitable capacitor (220pF ... 10nF) between DAC output and GND. In practice the DAC outputs must always be band limited prior to feeding the signal to the output stage. So called I/V transformers provide required band limiting. When using a (FET) current buffer together with the TDA1541A it's important to prevent the transistor or FET from switching off. This can happen when DAC output signal reaches zero (range 0 ... 4mA). In order to keep the transistor or FET conducting at all times, suitable bias resistor or CCS from DAC output to -15V must be used. After switching to MOSFET buffers with adjustable gate voltage, the value of the bias resistor could be increased as the DC offset can now always be set to zero, regardless of bias resistors. With 2SK170, the bias resistor also lowered the DC voltage on the DAC output by drawing extra current in order to meet JFET drain current when Vgs = 0. With the MOSFET converter I can now use 150K bias resistor to -15V. Quote:
This week I tested discrete series regulators, these were designed for large bandwidth, low noise and fast tracking. PCB size is small enough (11 x 28mm) to replace 78XX and 79XX regulators in existing designs. The regulators are based on 2 current mirrors (BCV61 / BCV62), 2 transistors, 5 resistors, and 2 LEDs (reference), so 11 parts in total. I designed both, a positive and negative regulator. Short circuit protection is provided by combination of constant current source driving the series transistor, and series transistor DC gain (around 40). Sound quality of these discrete regulators is a lot better compared to IC regulators. It appears as if IC regulators color the sound, add grain and limit resolution. Quote:
#3502 |
hello EC, what would be the correct value of the bias resistor when used in combination with 2SK170 ? thanks
#3503 | ||
Thanks John!
So understood flipflop is the one and now I know more about the stepped rectifier. Quote:
a) Put a 220pF and a resitor into the circuit b) put a 220pF and a CCS into the cicuit C) use Mosfets after your advise and plan. In the end the third option might be the way to go. But I'd like to try the other ones as well. For b) How many mA the CCS should draw? 1-2, or up to 4? Then it could be another K170 as well? Or for a) which resistor value you would choose? Quote:
Cheers Ernst |
#3504 |
Hello John
Finding good quality Jfet are difficult here arround. So I've mods an existing bjt I/V amp for a nos TDA1541A, there is an input and output 20khz low pass filters. What do you think of my circuit ? Thank Bye Gaetan |
#3505 | ||
Hi gaetan888,
I/V converter is built around T1 that's operating in grounded gate mode. Many different power MOSFETs can be used here. P1 taps suitable DC offset voltage from passive I/V resistor R1, blocks the audio signal using C1, and feeds it to the gate of T1. The "interference" that passes C1 only introduces ever so slight negative feedback as the interference is the audio signal itself. DC voltage at the DAC can be trimmed down to zero volts with multi turn trimmer P1. C2 band limits the TDA1541A output prior to feeding the power MOSFET current buffer. Bias resistor R2 prevents T1 from going out of conduction by drawing 100uA bias current. R2 value is high enough (150K) to minimize -15V rail noise injection. C3 blocks DC and is the only coupling cap in the signal path. One coupling cap is always required (safety) in case the I2S stream stops for some reason and the DAC chip latches the last received data. This converter has approx. 14 Ohm input impedance, this results in approx. 56mVpp at the DAC output. 50mVpp would be ideal (+/-25mV compliance) but it comes very close. This converter feeds all bit currents into +5V DAC power supply for best performance. Note that volume pot P2 is connected in parallel with the passive I/V resistor R1. GND of both converter and power amp must not be connected. This removes the DAC +5V power supply from the direct signal path. So I am basically "measuring" the ac voltage across R1 only. The thingy on the right is my latest Circlotron MOSFET power amp. PowerFETs T1 and T2 form a differential input stage (gain = 15). P1 sets the bias current (and voltage drop across R5 and R6). This in turn sets the bias current in the Circlotron bridge output stage built around Power MOSFETs T4 and T5. P3 sets the DC-offset voltage on the speaker output (note that this power amp is fully DC-coupled!). C4 and R4 fixes the gain difference between T2 (grounded source, high gain) and T3 (grounded gate, lower gain). R7 and R8 provide reference for driving powerFETs T4 and T5. The Circlotron bridge output stage doubles the output signal across the speaker (measured total gain equals 30x). With 0.7V rms DAC output this results in max. 21V rms across the speaker. This enables max. output power of approx. 55 watts rms in 8 Ohms or 110 watts in 4 Ohm. Because of the use of power MOSFETs exclusively (substrate mounted on heatsink), thermal memory effects are minimized. The few components in the signal path ensure both, very high resolution and transparency. Quote:
Its a clever design but has drawbacks. Filters are debatable, I try to avoid them whenever possible (phase shifts). The TDA1541A operates optimally when all bit currents flow back into +5V TDA1541A power supply. This is not the case here. You need 2 very high quality wire wound passive I/V resistors. These resistors make or break sound quality as they perform actual I/V conversion. TDA1541A only sinks current and sinks 2mA bias current, this might affect circuit performance. Both C1 and C2 are over dimensioned, lower value film caps can be used instead. R12 injects significant power supply noise into the DAC outputs. Last edited by -ecdesigns-; 12th November 2010 at 08:49 AM. |
#3506 |
Hello John
I only have BS170R mosfets, is it ok ? I've redraw your circuit so it be connect to the TDA1541A, to be sure I've understand it correctly. Is there any error in my redraw of your circuit ? Thank you Bye Gaetan |
#3507 | |
Regards Ernst |
#3508 | |
Hi gaetan8888,
I haven't re-checked this but the bias resistor (and resulting current) also affects converter input impedance. With BS170 output compliance of 50mVpp is fully met when using 5K bias resistor. In practice it's a trade-off between meeting output compliance (low bias resistor value) and minimizing noise injection from the -15V rail (high bias resistor value). You can experiment with bias resistor values between 5K and 100K and settle for the value that offers best perceived sound quality. |
#3509 | |
Hi ernesternest,
I had no clean negative bias voltage available (power supply pollution) to pinch-off the JFET reducing the drain current to required 2mA. So I used a 3mA bias current instead. The bias resistor also prevented current interruption through the JFET when DAC output current equals zero (DAC output is basically disconnected / floating in this case). With the MOSFET converter I have a trimmer for adjusting source voltage to zero by varying Vgs. So the bias resistor is no longer required for trimming DC voltage at the DAC output to zero. It is however still required to prevent the MOSFET from going out of conduction (similar as with the JFET). But bias current can now be lowered depending on required converter input impedance. |
#3510 | |
Missing few parts to built it for now, but I've simulated it, using a 2ma sine current source to replace the TDA1541A It's not as the real TDA1541A since that using more sine current source do overload it. Here is the image and the Ltspice asc file into a text file. Thank Bye Gaetan Last edited by gaetan8888; 13th November 2010 at 06:41 AM. |
