Go Back   Home > Forums > Source & Line > Digital Line Level
Old 4th February 2009, 10:53 AM   #2501
ccschua is offline ccschua  Malaysia
referring to the photo below
For U1,
Q0 = Q1
Q1 = Q2
Q3 = Q4 .... so on. the drawing use a different convention. I will use Q1 convention (instead of Q0)
Since CS8412 is doing 4 times, I need to get CS8412 in NOS. to get to 4x oversampling, I bent pin 9 (Q1) and short pcb pin socket pin 9 (Q1) to pin 7 (Q2). Q2 = 2.82 MHz. Which means U4 CS 8412 FCK is receiving the 2.82MHz instead of 5.64MHz. Is this correct ?
Old 4th February 2009, 05:06 PM   #2502
-ecdesigns-'s Avatar
Hi ccschua,
FCK (pin13) can be used for connecting an optional 6.144 MHz external clock for providing information about source sample rate. So the 5.6488 MHz clock used here doesn't comply with the specs in the data sheet. I don't use this FCK pin and connected it to GND so it won't pick-up interference.
X1 runs at 11.2896 MHz (4 x bit clock). The actual bit clock (for NOS) is at U1 pin 7 (2.8244 MHz).
The word clock is available at U1 pin 13 (11.2896 MHz / 256 = 44.1 KHz).
So when the SAA7220 is bypassed, the DAC already runs in NOS mode (2.8224 MHz bit clock and 44.1 KHz sample rate).
Old 5th February 2009, 03:23 AM   #2503
MGH is offline MGH  United States
Wink So is the DI4T ready?
Seems like years since this thread started. We like to see the finished product....Pretty Please
Old 5th February 2009, 05:18 AM   #2504
Originally posted by -ecdesigns-
Hi ccschua,
Dear John,
reffering to that dac kit,the Hong Kong seller from ebay wrote it's specifications to be 8x oversampling,please check this link with also schematic included
http://cgi.ebay.com/Hi-End-CD-DAC-TD...742.m153.l1262
"SPECIFICATION
1. 16 bit DAC for Hi-Fi Audio
2. S/N can attain 110dB
3. 8x oversampling frequency"
so my question would be,where from does he obtain a 2x oversampling in case we leave saa7220 in place (that does the 4x oversampling)
also check Doede's dac using a simillar reclocking circuit,he is grounding pin 13 on CS8414 just like you said
ps. sorry to polute your original thread with these kind of questions
Old 5th February 2009, 08:33 AM   #2505
Hi MGH,
No, the DI4T is not ready, in fact design was put on halt.
It IS years since I started this thread on May 12, 2006.
This thread illustrates how difficult it is to design a high-performance DAC.
At the end of 2008, all previous developments started to produce a clearer picture of the problems involved. Next, each problem was systematically tackled, and most significant progress was made. Just when I assumed that the highly optimized (and also rather complicated) DI4T would be the "ultimate NOS DAC", and it would only be a matter of designing the final PCBs for it, the unexpected happened. The simple breadboard test set-up that was used for testing the new DI4T modules, sounded rather good. The "problem" was that the test set-up had a single TDA1543 DAC chip.
Comparison with the DI4T reference DAC left me baffled, there was little audible difference. It was a rather frustrating experience after all the hard work put into DI4T design and tuning.
The messy breadboard test set-up evolved to the messy D1M prototype. Maximum performance was squeezed out of the TDA1543 chip by using a low jitter masterclock / tracker module, a new high-performance trans-impedance I/V converter / buffer, and low noise shunt regulators. The D1M now clearly performs much better than the DI4T reference DAC.
So why not go for the much simpler, cheaper design that offers even better sound quality than my DI4T reference DAC?
Old 5th February 2009, 10:15 AM   #2506
hmmm,not many people, especially design engineers that perform a business selling hi-fi equipment, would tell the truth to their customers about cheaper better sounding devices,...their marketing policy is to sell the most expensive devices with most profit even if it is a bullsh*t (generally speaking,i was not reffering to your better,more expensive product here)
so,not as if it would matter,but ecdesigns gets my whole appreciation for his remarks !
== NIHIL SINE DEO - Nothing Without GOD ==
Old 5th February 2009, 02:47 PM   #2507
Originally posted by luxury54
"SPECIFICATION
Sorry I polute the thread here, but I can not stop to yell 'wow'. With the pin 13 of CS8412 connect to ground, the sound has open up more as if more transparent and fill with energy. It is very vicacious especially from the acoustics of Andy McKee and Allan Taylor.
Old 5th February 2009, 02:53 PM   #2508
Hi luxury54,
The schematic shows a single TDA1541A running in time multiplex mode I2S (pin 27 connected to VCC).
TDA1541A data sheet specifies max. bit clock frequency (fBCK) of 6.4 MHz (TDA1541A data sheet page 2), this prevents using OS rates higher than 4x using I2S (time multiplex mode).
SAA7220 data sheet specifies: The filtered data is output in I2S format at 5.6448 MHz bit rate, and a sample rate of 176.4 KHz (SAA7220 data sheet page 7).
The resulting OS factor would be 176,400 / 44,100 = 4x.
The TDA1541A can run at 8x OS when using simultaneous mode (pin 27 connected to -5V, TDA1541A data sheet page 5). Now data for both L and R channel can be clocked-in simultaneously, requiring only 16 bit clock pulses instead of 32. This would effectively double the amount of samples that can be clocked-in while staying below specified 6.4 MHz bit clock. The sample rate will then be:
5,644,800 / 44,100 / 16 = 8x.
This is also the max. sample rate for a single TDA1541A chip.
Old 5th February 2009, 03:13 PM   #2509
I never learn this in university, but the audio university.
All this while, I thought I was running at 8x which is printed at the manufacturer website. I am totally wrong. So it sounds like tda1541a running in 4x is quite balance.
To do 8x, I need to bend pin 27 of TDA1541a and solder it to -5V.
Then can I know how to connect the SAA 7220 to TDA1541a ? I need to use DOBM to output 32bit word to pin 3 and pin 4 ? any other changes as per the schematic.
Old 5th February 2009, 03:32 PM   #2510
JC951t is offline JC951t  Taiwan
Hi John,
I was waiting for the arrival of the DI4. Have been hunting for
the 1541s & now this post. Hmmm. Hey, maybe single 1541
would sound better then the 1543. Have you tried it ?
Copyright ©1999-2013 diyAudio
