Building the ultimate NOS DAC using TDA1541A
Old 31st January 2009, 04:11 PM   #2491
ecdesigns is offline ecdesigns  Netherlands
Hi Builder Brad,
I have just updated the charge transfer schematic to show the connections for transformers without the centre tap - is this the correct way to connect these?
You need to use a rectifier bridge (requires 4 rectifier diodes).
after about 5 minutes of playback the right channel starts to distort
This is probably caused by tolerances, as the DAC chip heats-up, the voltage across the internal diodes (digital input circuit) drops. This can be solved by lowering the series resistor value, you could try 2K2 or lower.
Old 31st January 2009, 04:28 PM   #2492
Telstar is offline Telstar  Italy
Originally posted by -ecdesigns-
The derived 16.9344 clock with higher jitter is only used to clock the CD player, NOT the DAC chip. The DAC chip receives a (ultra) low jitter clock, derived from the 11.2896 MHz master clock.
Hello John,
May I ask you why you chose this frequency for your master clock? Wouldnt higher be better?
Availability?
"The response of the inner ear extends to at least 200khz" Dr W. Tempest
Old 31st January 2009, 04:29 PM   #2493
Hi gaetan8888,
How can we use a DIR9001 in your DI4 dac ?
The SPDIF receiver, used together with the master clock / tracker module, needs to run in slave clock mode, it seems this mode isn't supported by the DIR9001.
Old 31st January 2009, 04:51 PM   #2494
Hi Telstar,
Availability?
I planned to support 44.1 KHz sample rate only, I used 11.2896 MHz because of availability of required crystal.
Then I ran into troubles with my satellite receiver that outputs 48 KHz sample rate.
Today this problem was fixed.
My brother successfully completed the firmware for the new multi-rate master clock / tracker module.
This micro controller-based multi-rate tracker / master clock module automatically detects and tracks 44.1 KHz, 48 KHz, 88.2 KHz, and 96 KHz sample rates. It uses 2 crystals (11.2896 and 12.288 MHz), and a programmable clock divider to support these sample rates.
So I now have a highly effective source jitter blocker that accepts 44.1, 48, 88.2, and 96 KHz sample rates. These sample rates are supported by Toslink, and are within TDA1541A / TDA1543 bit clock specs.
Old 31st January 2009, 06:43 PM   #2495
Builder Brad is offline Builder Brad  United Kingdom
THANK-YOU JOHN,
"You need to use a rectifier bridge (requires 4 rectifier diodes)"
I thought that your schematic was giving half wave rectification - providing plenty of time for the mosfets to switch and transfer the charge - looking at the details again I can see that the centre tapped transformer is also connected up for full wave rectification.
congratulations on you solution, regards the sample rate input firmware.
Old 31st January 2009, 09:39 PM   #2496
gaetan8888 is offline gaetan8888  Canada
Hi gaetan8888,
Hello John
I can not have the CS8412 or CS8414 here arround and buying them from out of Canada would cost way too much with the shipping.
But I can have the AK4114, AK4116, AK4117, WM8804 (very low jitter), DIR9001 (very low jitter), or maby the CS8416.
Do I really need to use the receiver master with a clock/tracker module and in slave mode ?
Maby I could do could do a simplier version of the DI4 with one of the receiver that I can have ?
Thank
Bye
Gaetan
Old 1st February 2009, 12:22 AM   #2497
Jean-Charles is offline Jean-Charles  Canada
Hi John,
I had prepared such a circuit with a full bridge rectifier that I intended to use.
To return to your original circuit we only need to remove D3, D4 and add the jumper.
This way we can use a transformer with center tap or a single winding.
I also worked on a pcb for this circuit. I still need to ajust the footprints for various capacitors to use.
I would appreciate you check it out, if it would be usefull to others on this thread.
Old 1st February 2009, 08:51 AM   #2498
Hi gaetan8888,
Both AK4114, and WM8804 support slave-clock mode and seem to be suitable. I use the CS8416, it's placed on a module, so I could easily swap between various SPDIF receiver chips.
Depends on the sound quality you want to achieve, I tried many different solutions. I started with a CS8412 in master mode (coax and RS422 twisted pair), and experimented with direct I2S (DATA, CLOCK and WS signals transmitted using 3 x RS422 twisted-pair).
Next I tried USB / direct I2S, using an asynchronous reclocker (USBDI2S module), later an USB / Toslink combination module was designed (UTOS1 & 2), I2S signals from USB were routed through high-speed opto-couplers, and SPDIF was routed through Toslink. Asynchronous reclockers were used to attenuate source jitter. During these experiments, the advantages of full galvanic insulation became clear.
Then I experimented with running a SPDIF receiver in slave-clock mode, directly feeding the crystal oscillator signal to the DAC chips. This was a big improvement, but the lack of synchronization between both source and master clock produced audible cliks, best audible when playing-back sine waves.
In order to solve the synchronization issue, I then experimented with a VCXO / PLL circuit, this circuit was first used in both DI4T and DI4MJ, and it was integrated on the mainboard. The clicks were gone, but still sound quality wasn't optimal.
So I decided to replace the analogue PLL with a micro controller-based frequency tracker that only performs corrections with 2 second intervals. This solution works fine, and I designed a PCB that holds master clock, tracker and clock buffers.
In order to expand the functionality of this tracker circuit, a multi-sample rate support was added, so the tracker could be used with popular sample rates. It would also be possible to support 176.4 and 192 KHz, using the same 2 crystals. This possible option will be included in the new design. In that case the tracker could automatically detect and track 44.1, 48, 88.2, 96, 176.4, and 192 KHz.
Old 1st February 2009, 02:11 PM   #2499
Originally posted by Jean-Charles
Hi John,
I don't know what hapenned, the pdf file did not follow.
I try again, hoping it will work.
Old 2nd February 2009, 12:24 AM   #2500
Hi gaetan8888,
Hello John
I would like to keep it as simple as possible and I'm limited in my budget, at least I have the four TDA1541 chip.
I just done a search in the forum and found in your thread a sync reclock post and schematic;
http://www.diyaudio.com/forums/showt...60#post1317660
And the schematic link;
http://www.diyaudio.com/forums/attac...amp=1191570449
Any littles mod suggestions on this schematic ?
How about using it for the DI4 dac ?
Thank you
Bye
Gaetan
Building the ultimate NOS DAC using TDA1541AHide this!Advertise here!
