| Digital Line Level DACs, Digital Crossovers, Equalizers, etc. |
#1771 |
OK Tubee, I understand that. I will disconnect cable's shield at TVC's input and RC filter to ground the PIN1 input and see what happens. Anyway a +/-5MHz sine about 10mV pp, considering the secondaries low potential might affect the amps...or it may get filtered at amp's input circuit instead.
I'll check TVC with square waves instead with my new-old function generator ...and also, if time allows, I will take a look at DI16 circuits...and at my amps, and my....and my... Sorry for the OT Cheers, M
"Thou shall build big horn speakers" |
#1772 | |
This shared clock now provide the 352.8 Khz for the DEM Clock. I don't have any scope but listening sessions leads me to the conclusion that it's really worth the case: Sound becomes clearer, what was really noticeable (on my system) is the air it provides between instruments . Due to it, the soundstage turns accurate, it's easier for instance to follow the background bass player... voice remains unprojected but are more detailed. To conclude Joe Sample piano lays precisely in the background while R. Crawford sings clearly in front of me... ![]() I can't imagine what it could gave with 8x 1541A
#1773 |
Hi all,
Finally another update, This one was initiated by onnosr, telling me he heard slight performance differences between USBDI2S module and SPDIFDI2S module. This puzzled me a bit since both reclockers used identical reclock circuits, except for the SPDIFDI2S module being connected to a clean 5V power supply..... The BCK clocking scheme bugged me for some time, I also wasn't happy using multiple reclockers. So I decided it was time to improve this. This weekend I designed / installed the local reclocker. The reclocker is placed directly on the DI16 / DI8M core PCB to ensure shortest BCK signal path, it reclocks BCK from both USB / PCM2706, and DI2S. It provides an extreme low jitter clock directly at the DAC chip inputs. The existing reclockers on both USBDI2S and SPDIFDI2S modules were removed / bypassed. I put a custom 12 MHz oscillator in the USBDI2S module (74HC161 IC socket) for PCM2706 clock. The clocking scheme has been simplified / improved: Old situation: USB > PCM2706 > reclocker > I2S > DI2S > I2S > I2S interlink > clock buffer > DAC chips DI2S > I2S > I2S interlink > clock buffer > DAC chips (no reclocking) note: The DI2S buffers are used to attenuate common interference, and provide I2S source selection. New situation: USB > I2S > DI2S > I2S > reclocker > clock buffer > DAC chips DI2S > I2S > reclocker > clock buffers > DAC chips Note: both digital audio sources are now reclocked. The reclocker can now run on an external clean power supply (no longer connected to USB power supply). The photograph shows the local reclocker in my DI 8M reference DAC, another reclocker is placed on the heatsink for a better view. This reclocker can also be used with the DI 16. Measurements: The oscillograms taken directly from the TDA1541A chip BCK inputs show very clean rasor-sharp transients, now it's no longer possible to measure the jitter with my oscilloscope, even after minimum brightness setting and focus fine-adjust. First impressions: The improvement is immediately audible, no direct comparisons necessary for this mod. The sound-stage is wider, sound is smoother, cleaner and more detailed than before. Even at low volume settings the sound quality is exceptionally clear and detailed. |
#1774 |
That is great news John.
Now we can even improve USB module or just added after. MaxLorenz you were right about 8X4 mode. My DI16 8X4 performing very well. Clear sound, much better than DI16 basic. I had hard time to make alu towers by hand (2-3 weeks), still i used thermal paste and silicon pads to get good thermal contact. CNC machine would be best for that work. But now enjoying. I am completely enthusiastic about this DAC, i ordered also TUBE DIF PCBs. regards, Bostjan |
#1775 | |
Hi John, hi Bostjan
John, why are you so cruel? Now you have to guide about how to mod my setup. As I understand, now you have two 12Mhz clocks, right? One for PCM2706 and one for BCK. Why don't we use a 11.28Mhz for BCK, instead, since it has its own low noise PS??? Quote:
Well, it is true that 1543 is a low resolution DAC. With 32 DACs you gain in resolution, while retaining that warmth and intimacy that NOS gives. I would love to be able to get one DI8, though. But I'm risking divorce here (3 DIY systems; 5 digital sources; planning even bigger horn speakers)About, heatsinks for the towers, lovely job, ain't it? I'm sure there will be a cheap alternative in the future Cheers, M PS: I have here 20uF, SMD tantalum caps and X7R smd 0603 caps that I could use as PS bypass for the towers (bottom side) instead of the stock setup...what do you think John?
#1776 |
-ecdesigns-:
I'm getting ready to make the plunge! I have half the parts and will be placing an order in a week for the rest. I just had the chance to open up my current transport and peek inside... Unfortuantely, I'm not sure it is compatible with the Philips i2s standard. However, I do not have the expertise to determine for sure. The chip used is Panasonic MN66271RA. Here is a datasheet: http://www.ortodoxism.ro/datasheets/.../MN66271RA.pdf There are no timing diagrams. Pins 1,2,3 are available, but very small pads They are BCLK, LRCK, SRDATA. There are a few frequency adjustment pins and a number of clocks present as well. Is there a hope for this working, or should I sell this transport and look for a new one that will be easier to modify?Thank you! |
#1777 |
I wanted to purchase a set of PCB's with difficult parts already soldered, but I can't find a place to order on your website. Should I email you?
#1778 | |
I just read through this very interesting thread and I'm think that I will make this DAC. But I have questions about the above statement. Can you define "low amplitude phase noise" because in your diagram you show it as full amplitude random timing irregularities. Can you describe how this phase noise disrupts high feedback amps differently from the asynchronous clocking deviation that you say does not disrupt them. The only things that I am aware of that disrupt feedback amps are frequencies above that which a circuit can handle. My guess is that the low feedback circuit is simply smoothing over the HF noise problem while the high feedback circuit is having a try at resolving an input signal which it cannot handle and is it therefore making a mess of. but why do "random timing irregularities" create a more challenging task for o/p stages than asynchronous re-clocking timing irregularities - it does not seem logical to me. I do tend to believe that you have made a rather special DAC and I am very interested to listen to it. My question is why is it good ? I can understand that eradicating the ringing present with oversampling is a big advantage because for me ringing = HF noise and noise is No1 enemy of high fidelity reproduction but at present this whole timing / clocking issue is a mystery to me ( unless we simply ascribe it to being a psycho acoustic phenomena ). cheers mike |
#1779 |
Hi rtd,
I also have a simple SA7220/CS8414/TDA1541A DAC and am interested in your "simple shared reclock board for BCK and the SA7220 (allowing to bypass the SA7220 internal clock)". Can you share with me more information on this? Thanks & Best Regards S K |
#1780 | |||||
Hi mikelm
So there is a big difference in jitter spectra (noise vs square wave) The shiftregister reclocker works much more accurate than a plain asynchronous reclocker. The newest version manages to exactly align 99.96% of the output pulses, using a 48MHz masterclock. A plain asynchronous reclocker can only align approx. 50%. Quote:
And it's not only amplifiers, all circuits and components that need to process the audio signal, must be able to cope with both the audio signal AND the accompanied higher harmonics. By this I mean it should respond fully linear over the required bandwidth, adding no extra distortion. Problems with higher harmonics occur in the D/A converter itself, I/V converter, differential amplifiers, and analogue reconstruction filter. It would help if higher harmonics could be reduced to start with. This is exactly what a NOS DAC does (remember the higher harmonics also have to pass the analogue part of D/A conversion stage). Band limiting / filtering hasn't occurred yet in this stage. Despite OS brickwall filtering, it's the analogue reconstruction filter that actually attenuates higher harmonics to some extent. The un-attenuated higher harmonics already caused havoc in the D/A, I/V, differential stages and analogue reconstruction filter by then. Quote:
- No analogue filters (extreme low phase distortion) - Direct interpolation (increases both time and amplitude resolution) - Zero ringing - Extreme low jitter timing signal at DAC timing inputs (local reclocker) - Multiple DAC chips in parallel (reduces bit errors) - Balanced design (cancels common interference) - Very high amplitude internal signal levels (noise immunity) - Accepts USB, I2S, DI2S and SPDIF / TOSLINK (connects to most digital sources) - Full galvanic insulation between source and DAC (new digital front-ends), prevents ground loops and blocks source noise - Unique mixed-mode output (balances both odd and even harmonics) - Modular design (allows for easy future upgrades) - Selected components (low level tuning) - Class A operation of operational amplifiers (less crossover distortion) Quote:
Depending on how our hearing interprets this band limited signal, it might sound different from the original square wave. It's likely that more complex audio signals make the effects of ringing as a result of band limiting more audible. Ringing could be reduced by significantly increasing both bandwidth and sample rate, this however isn't very practical for the reasons I already indicated. The whole timing and clocking issue results in 7 or 15 linear interpolated samples placed between the existing samples in real-time, (Direct Interpolation). This increases both time resolution (from 44.1 KHz to 352.8 or 706.5 KHz), and amplitude resolution (from 16 bits to 19 or 20 bits, however this depends on tolerances). In the process it also acts as a linear filter, effectively attenuating higher harmonics, but since it's no brickwall filter, intermodulations with fs still occur, as fs is too close to the audio range. However, higher harmonics are effectively attenuated. This is the reason why I can leave-out the analogue filter, similar to the Trinity DAC. Because I use multiple DAC chips, each chip has to process less higher harmonics, as it runs at fs (NOS mode), and part of the interpolation takes place in the analogue domain as well. |
