Least expensive 6-channel volume control for DCX2496? - Page 3 - diyAudio
Go Back   Home > Forums > Source & Line > Digital Line Level
Old 21st February 2006, 08:52 PM   #21
sendler is offline sendler  United States
Default Six knobs that click
Six knobs that click aren't any harder to adjust than one knob. Click, click, click, click, click, click, vs. turn. The difference is about the same amount of time that it took to read that sentence. If you are going to give up remote control then the real consideration is walking over to the amps. After you are there, turning one knob or six is not that much different. Six knobs (or even three) that don't have matched steps would be very difficult to get repeatable settings, however. With the stepped attenuators it is easy to get any volume that you want and keep all of the channels perfectly matched. The real question is to remote or not to remote and comes down to how much emphasis is to be placed on sound quality vs. convenience. When the payoff is this great, I will chose sound quality every time.
Scott
Old 21st February 2006, 08:56 PM   #22
Default Re: Six knobs that click
Good point sendler, and like I said above, ganged pots might make it less than 6... I think it really comes down to how you listen to music.. If you are constantly adjusting the volume for each track then this may not be the best idea, but if you can set the volume once and leave it then passive attenuation is the best way to go...
--Chris
Old 21st February 2006, 09:00 PM   #23
tf1216 is offline tf1216  United States
Scott,
Could you please post a pic(s) of your system with the passive attneuators in use? I am a little confused on the exact setup but I love the idea of 3 in a box.
I am extremely interested in buying 5 and getting 1 free. Thanks!
It seems like this may be the best route for us guys who are using the DCX2496 for volume control.
Old 21st February 2006, 09:26 PM   #24
jan.didden's Avatar
Originally posted by tf1216
janneman:
Can you please elaborate more on the K5600? What do you think of the unit and its performance so far? How is it different than a Roland M1000?
[snip]
The K5600 is very easy to put together, couple of hours, worked from power up. I find it more neutral than using the DCX digital-domain level control, although it is not the worlds best preamp, obviously. But its pretty good. It can be used with almost any RC5 compatible remote so that is definitely a big plus for me.
Disadvantage of the K5600 is that you cannot set levels separate for each channel, its all or nothing. That said, it uses 3 LM1973's and the hardware setup is such that with a change in the software you can address each of the three channel pairs separately, which is what you probably would need for the DCX. It's on my list, I've done these things before (built & programmed a remote control PIC-driven preamp before) but I don't know when I will get the time.
Then again, for 200 aussi $, how can you lose? Buy it, try it and sell it for 130 if you don't like it anymore.
Jan Didden
Music is dither to the brain; lets me think below the usual chaos - me
Linear Audio Vol 12 is out! Check out my Autoranger and SilentSwitcher
Old 6th April 2006, 03:51 PM   #25
Beside the K5600 there's another solution now 6 channel volume control .
This one offers separate adjustment on each of the 6 channels (+/6dB) in addition to the main volume setting.
I'm very happy with both of them.
Oh, by the way I have been fortunate enough as I've been offered the Selectronic as a gift
Thierry
Old 6th April 2006, 03:54 PM   #26
Any idea where I could find one of those in the US? Also, any idea how much it costs?
Thanks!
Old 6th April 2006, 03:59 PM   #27
Hi Mazeroth,
I've got the prototype (i.e. serial 00001)
First production run will probably be available at the end of april.
Price has still to be determined, I'll know it in the next few days.
Shipping cost to the US and form of payment are being defined by Selectronic (I advised them to used Paypal which is really smooth).
Alternatively : I'll be back to you here with the details, or you may enquire from the address I indicated on my web page.
Cheers
Thierry
Old 6th April 2006, 04:07 PM   #28
Are each channel adjustable +/- 3dB or +/- 6dB?
Just curious...
Old 6th April 2006, 04:09 PM   #29
Very good question indeed. Let me check that, I'll be back here with an answer.
Cheers
Thierry
Old 6th April 2006, 05:05 PM   #30
It's definitely +/- 3dB, sorry for misleading you people.
DCX2496 and volume control RogerCl Digital Line Level 29 27th September 2009 12:35 AM
FS: 6-channel volume control (DCX2496) tf1216 Swap Meet 10 3rd October 2008 12:01 AM
6-channel volume control for DCX2496 tf1216 Swap Meet 4 17th August 2008 09:50 PM
DCX2496 DAC volume control PCB bdipoala Swap Meet 16 6th April 2008 08:18 PM
DCX2496 Volume control bdipoala Swap Meet 14 9th September 2007 11:57 AM
Copyright 1999-2017 diyAudio
