Go Back   Home > Forums > Source & Line > Digital Line Level
Old 22nd November 2009, 01:04 PM   #541
loris.p is offline loris.p  Italy
loris.p's Avatar
Default Dic
John,
I'm still playing with my Cardinal/Ordinal. I've come across this Dic. I thought it was a modified clock lock dic but I guess it's a modified bnc standard dic. Can you tell some more?
Loris
Old 22nd November 2009, 03:22 PM   #542
JohnW is offline JohnW  Hong Kong
JohnW's Avatar
Your modified DIC - (Digital Input Card)
Hi Loris,
Yes its a standard BNC input DIC, however someone has added an RCA in parrellel with the BNC - however the RCA appears wired after the the AC coupling capacitor - which could cause problems depending on source. If you want to use the DIC with the RCA (not recomended due to the Risk of earth leakage current damage) - you should wire the RCA DIRECTLY in parrellel with the BNC - so before the Ceramic coupling capacitor.
John
Life shouldn’t be take it too seriously, you will not come out alive anyway…
Old 24th November 2009, 02:01 PM   #543
JohnW's Avatar
Default Balanced AES/EBU to 75Ohm SPDIF conversion.
"The Moog"
This is a LINK to an application note by Rane Corporation (RaneNote 149) which goes into some detail concerning Balanced AES/EBU to 75Ohm SPDIF conversion.
So long as the DEQ2496 has true balanced AES/EBU outputs (I.e. its outputs are transformer coupled), then as the input's of the MDAC are also Balanced you will still gain the benefits of Common mode rejection of a balanced link – with Fig 1. providing the impedance and signal amplitude conversion.
John
Old 24th November 2009, 10:06 PM   #544
loris.p's Avatar
Default T1
John,
at a certain point in the thread you talked about a T1 transport too. Still scheduled?
Loris
Old 26th November 2009, 09:36 AM   #545
Hi John,
Great to hear that your designs are finally being released in one way or another :-)
You mention that the MDAC will work with the clock-link feature on some of the older Arcam CD players - do you know which Arcam CD players had this feature?
Steve.
Old 1st December 2009, 10:24 PM   #546
Originally Posted by JohnW View Post
"The Moog"
John
Many thanks for that information John,
Seems that the DEQ2496's AES/EBU outputs are indeed truely balanced, so this looks like a good option for me. Any further news on when we might see it arrive here in the UK? Any pictures of it allowed out yet ?
The Moog
Old 5th December 2009, 10:27 AM   #547
loris.p's Avatar
I’m happy to publish circuits and possibly design and ship small PCB’s that Forum users can retrofitted to there CD players to allow clock-locking – resulting in “Perfect” digital transports from “any old CD player” that has a Bit accurate SPDIF Data output.
So I guess I'll need an interface for the Cardinal
Old 8th December 2009, 08:18 AM   #548
Me too, as it seems the clock out on the new DAC is optical
Old 13th December 2009, 03:54 AM   #549
Curse you Westlake!
Rumbled me again,
Dan.
Old 14th December 2009, 07:14 PM   #550
Send a message via MSN to sq225917
@ Fauntleroy, NTSFS.
hoping to pick up some things.
John Curl - Parasound amp Issue Zero Cool Solid State 11 20th August 2008 08:41 PM
FS: Pink Triangle Da Capo (UK) minniedog Swap Meet 1 28th January 2008 01:21 PM
WTB:Pink Triangle Da Capo (non-functioning) Studley Swap Meet 2 28th January 2007 04:46 PM
Page generated in 0.11197 seconds (85.89% PHP - 14.11% MySQL) with 11 queries
