Da-capo issue (John W?)
Old 11th February 2010, 09:09 PM   #601
loris.p is offline loris.p  Italy
loris.p's Avatar
Well I've changed the caps. Now I'm listening the DaCapo ( with the 24 bit filter) and everything works fine, no white noise, but this means nothing because the noise wasn't always present.. I'll leave it on for a couple of days and then I'll see.....
John, am I right if I say that using the clock-lock dic without the clock cable, there are of low level cliks-clips-cliks.....?
Loris
Old 11th February 2010, 10:07 PM   #602
loris.p's Avatar
John, just U and I online now....
here it's snowing a little.....
Old 11th February 2010, 11:32 PM   #603
JohnW is offline JohnW  Czech Republic
JohnW's Avatar
Hi Loris,
Without clock cable - your lucky the Dacapo even produces audio - should indicate Lock, Low level clicks for sure - if not worst!
The Tranport and Dac are running without Sync. The Digitial Filter is "Soaking up" the timming differances - if you change to say 18 Bit Filter, you will find it will have a harder time...
Snowing here in CZ, does not stop. Bought a new car - had it less then a week (6 days) before a lady rear-end us while we waited at the lights...
John
Time is my worst enemy!
Old 12th February 2010, 08:21 AM   #604
loris.p's Avatar
Have you ever heard:
don't buy a new car while it's snowing?
Old 12th February 2010, 10:38 AM   #605
JohnW's Avatar
Hi Loris,
Now its my turn to say - I can't say if this is consolation..........
Hows the Dacapo?
John
Old 12th February 2010, 11:12 AM   #606
loris.p's Avatar
Originally Posted by JohnW View Post
Hi Loris,
John
I left the DaCapo hooked to a dvd/cd player ( optical link) in repeat mode all night long. This morning it was ok, no noise. Now I'm at work. I left it again on in repeat. I guess I'll leave it on for some day. I'll go home for lunch within an hour and I'll check it again.
Here's aPeachtree Idecco review:
http://www.avguide.com/review/peacht...7?src=Playback
BTW, if someone's interested I used Nichicon caps ( 8812519 at farnell)
Old 12th February 2010, 01:35 PM   #607
aparatusonitus is offline aparatusonitus  Croatia
aparatusonitus's Avatar
You’re basically developing a "Dacapo" Discrete DAC. A couple of points:-
The SAA7350 Bitstream outputs need to be re-formatted to "Return to Zero" Bitstream coding; otherwise you will have very poor THD+N due to "incorrect Pulse energy". Basically you need to logic "And" with the Master Clock - you also need to generate the Negative Data Pulse.
+ Pulse = Clock High & Data High
- Pulse = Clock High & Data Low
So you only can have a resultant Pulse (+ or -) if the clock is high - resulting in half pulse integration energy per clock cycle - but without "Edge Rise/ Fall time errors (If Balanced) & Missing Edge" distortion.
After Generating the 2 Phases from the Bitstream, you should then Latch to a Master clock 16.9344MHz, (in the case of the SAA7350 the Bitstream modulator is operating at half MCLK) - to resynchronise to MCLK and remove the Phase Noise (Jitter) from the SAA7350 outputs & subsequent Bitstream reformatting circuit. If you use a Dual D-FF with Q and Q-, then you can end up with 4 "Dac Elements" that can be finally summed.
The Bitstream outputs of the SAA 7350 are very heavily jittered - if you simply integrate its outputs directly you will hear all kind of "Birdies" due to its internal processing "Jittering" the outputs (typically heard as the Music ramps up and down in Level – such as the start of a track).
These 2 reclocked Output Phases need to be individually filtered then "differentially Summed" via an Opamp.
Thanks for the valuable input John...Now, how close I am?
Non é mai abbastanza...
Old 12th February 2010, 05:41 PM   #608
JohnW's Avatar
Hi Aparatusonitus,
Close your getting the idea, but....
Firstly, the XSYS 2 is very heavily jittered by the internal clock tree of the 7350. In your current implantation (if it worked), the final pulse energy would be also modulated by the jitter on the output of XSYS2.
Other issues - I cannot see how it would work... I will forward you a Schematic in the next 24 hours...
John
Old 12th February 2010, 09:12 PM   #609
loris.p's Avatar
Default DaCapo
24 hours of continuous working..... still no noise..... I cross my fingers but everything is ok
( isn't it that when the caps grow old they get sick untill they die of natural ( fixed) death? :-)
Old 13th February 2010, 12:52 AM   #610
JohnW's Avatar
Hi Loris,
Good News, however I suspect theres still an issue. Yes - Caps do age, however in this circuit application, Cap ageing would not result in White Noise....
Still snowing here....
John
Da-capo issue (John W?)Hide this!Advertise here!
John Curl - Parasound amp Issue Zero Cool Solid State 11 20th August 2008 08:41 PM
FS: Pink Triangle Da Capo (UK) minniedog Swap Meet 1 28th January 2008 01:21 PM
WTB:Pink Triangle Da Capo (non-functioning) Studley Swap Meet 2 28th January 2007 04:46 PM
Copyright ©1999-2017 diyAudio
