DCX2496 and Panny XR 6-Channel 3- Way Speaker - Page 2 - diyAudio
Go Back   Home > Forums > Source & Line > Digital Line Level
Old 2nd December 2005, 09:18 PM   #11
"I run dual XR-25s with my DCX2496."
How many channels of each do you use, and what's the signal path?
It adds anothe A/D conversion, right?
Someone should start a cottage industry converting the Pan receivers into 6-ch amps with digital inputs fro the DCX2496.
Noah
Old 6th December 2005, 01:02 PM   #12
I run a pair of Pannies for my three way active dipoles and use the spare channels for surrounds, with a pair of DCX2496s as the crossovers.
I don't use the volume on the receivers except to act as a master volume control (due to the way my sub is set up) but I may change this at some stage.
It all works just fine. Of course the ideal would be a DCX with digital outputs and a Panny with digital ins, but that ain't happening for a while.
Cheers
Steve
Old 6th December 2005, 03:27 PM   #13
BobK is offline BobK  United States
The Sony Receiver below is about the cheapest one I have found that allows six channel access. Has pretty good specs and I've seen it discounted in the past for around $300.
Old 6th December 2005, 03:29 PM   #14
Oops - forgot the link.
http://www.circuitcity.com/rpsm/oid/...cation.do#tabs
Melb. speaker DIYers, DCX2496 on Auction ttan98 Digital Line Level 0 21st November 2008 06:36 AM
FS: 6-channel volume control (DCX2496) tf1216 Swap Meet 10 2nd October 2008 11:01 PM
6-channel volume control for DCX2496 tf1216 Swap Meet 4 17th August 2008 08:50 PM
Least expensive 6-channel volume control for DCX2496? mazeroth Digital Line Level 35 8th April 2006 10:46 AM
DCX2496 3-channel digital rebuild LageB Digital Line Level 2 11th March 2006 07:00 AM
Copyright 1999-2017 diyAudio
