| Digital Line Level DACs, Digital Crossovers, Equalizers, etc. |
I've read everything on the DCX2496 that searches have turned up, but I'm still not clear on some of the basics.
1. Would a non-Golden Ear objectivist type person hear a degradation in sound when not using a digital volume control, i.e., using the volume-controlled pre-outs from a pre/pro? It seems that the 25 dB or so of volume range I normally use would still leave plenty of dynamic range. 2. Is the output from a typical consumer receiver sufficient to drive the DCX2496? 3. How user friendly is the DCX2496, in particular for adjusting the parametric EQ? Can it be adjusted in real time in one window of a PC while seing the RTA (from TrueRTA) results in another window? 4. Can multiple XO filters be cascaded to get, say, 96 dB/oct (aiming for poor man's DEQX)? Thanks very much
----------------------------------------- Noah |
#2 |
Post your email address and I send you some info
#3 |
thylantyr,
I unhid my email; does that mean spammers can find it? Anyway it's noah dot katz at lmco dot com Thanks, I appreciate it
#4 | ||||
The parametric equalizer is very easy to use. If you are programming from the PC interface, it graphs the transfer function as you set it. Quote:
HTH Doug |
#5 |
Thanks, Doug, that's what I wanted to (not) hear
| Behringer DCX2496 | 12 Cents | Swap Meet | 0 | 29th July 2007 08:27 AM |
| Behringer DCX2496 | RAAMaudio | Swap Meet | 0 | 19th February 2006 07:15 PM |
| Behringer DCX2496 questions | noah katz | Digital Line Level | 18 | 23rd October 2005 07:49 PM |
| Behringer DCX2496 Questions | DougL | Digital Line Level | 14 | 18th May 2005 02:49 PM |
| Behringer DCX2496 12v ps | Flyingeyepro | Car Audio | 0 | 30th July 2004 08:05 PM |
| Page generated in 0.08815 seconds (73.92% PHP - 26.08% MySQL) with 10 queries |
