Go Back   Home > Forums > Source & Line > Digital Line Level
Old 20th October 2005, 11:35 PM   #11
George,
I'd be using TrueRTA with 1/24th-octave resolution.
Do I presume correctly that multiple memory settings consumes minimal resources?
Also, is it correct that there's a third analog input I can use so that I can biamp three channels?
"figuring the digital stream doesn't handle above 20kHz or below 20hz -could be wrong"
I hope that's not the case, I'm going to build subs with two each Avalanche 18, w/strong output down to 10 Hz.
Noah
Old 21st October 2005, 12:02 AM   #12
float is offline float  England
Noah,
if you can use these other toys the BFD should hold no fear; its simple to use even though the manual may be needed at first.
I've only got the old one (DSP1100?), and its a bit noisy and not totally transparent; the latest model should be much better.
If you only need 12 stereo bands of parametric it may do the job.
I w isH i cuold typpe bettr
Old 21st October 2005, 12:07 AM   #13
float,
"if you can use these other toys "
So far it's still "if"; I don't have them yet.
I'm a bit short on patience and get rankled when it starts taking a lot of time.
Re the BFD, I just as much want the XO function for the LCR's I'll be building.
Noah
Old 21st October 2005, 08:33 AM   #14
Hi Noah
Memory I believe is seperate from procsessing issues - the dcx has quite a few memories to play with to retain different settings.
Not sure about the third input - have a look at the manual , it contains descriptions of various config options.
I was very hesitant about buying this unit due to all the negative flack it receives, but in my case i am very glad I took the leap.
Cheers
george a
Old 21st October 2005, 08:52 AM   #15
what hardware (cheap) and software do you need to control the DCX from the PC?
regards Andrew T.
Old 21st October 2005, 09:44 AM   #16
johnnyx is offline johnnyx  United Kingdom
Andrew
For hardware you just need a serial cable to the PC serial port.
Software is a free download from Behringer's website, which is linked by George in post #6.
I haven't had a good play with mine, I'm building a new amp, hopefully it will be finished soon.
Old 21st October 2005, 05:56 PM   #17
Thanx Johnnyx
regards Andrew T.
Old 21st October 2005, 06:27 PM   #18
I took a look at the manual, triple biamp is one of the standard configurations w/preset.
Noah
Old 23rd October 2005, 07:49 PM   #19
For getting six amp channels w/volume control affordably, how about using the 7.1 direct inputs from a used receiver w/good quality amps?
Noah
Behringer DCX2496 12 Cents Swap Meet 0 29th July 2007 08:27 AM
Behringer DCX2496 RAAMaudio Swap Meet 0 19th February 2006 07:15 PM
Behringer DCX2496 questions noah katz Digital Line Level 4 21st October 2005 05:43 AM
Behringer DCX2496 Questions DougL Digital Line Level 14 18th May 2005 02:49 PM
Behringer DCX2496 12v ps Flyingeyepro Car Audio 0 30th July 2004 08:05 PM
Page generated in 0.09659 seconds (76.34% PHP - 23.66% MySQL) with 11 queries
