diyAudio
diyAudio (http://www.diyaudio.com/forums/index.php)
-   Digital Line Level (http://www.diyaudio.com/forums/digital-line-level/)
-   -   Behringer SRC2496 mods (http://www.diyaudio.com/forums/digital-line-level/65713-behringer-src2496-mods.html)
Cobra2 10th October 2005 02:06 AM
2 Attachment(s)
I just got a new toy...:D
Here is what you get;
Arne K
Cobra2 10th October 2005 02:10 AM
The first update
2 Attachment(s)
follow the *must do* from datasheet, and decouple the CS8420 on its pins: (picture)
Next; (if you will use as DAC), change op-amps, upgrade trafo/psu...
Arne K
joe 10th October 2005 11:47 AM
Hi Arne,
do you like what you hear? Which DAC is inside?
greetings
Arndt
FLECOM 10th October 2005 12:59 PM
Behringer usually uses AKM dac's I am just wondering if they are they the same as the ones in the DEQ2496?
Cobra2 10th October 2005 03:16 PM
Yes, the same...
(I do not think it sounds as good as the DEQ...but have not done any extensive upgrades yet).
ArneK
gmarsh 11th October 2005 01:04 AM
the SRC2496 uses a CS8420?!
no :(
Cobra2 11th October 2005 07:53 AM
Afraid so....
Arne K
aaronboumans 10th April 2006 01:26 PM
cobra2,
I am getting the src soon(secondhand)and I have a question;
is your added capacitor a 1000pF? or the 0.1uF?
According to manual both are needed.
zanash 16th September 2006 01:18 PM
I've had a play with this unit, and do the following
SRC mods.......
damped the case and lid with bitumen sheet.
replaced the rectifier diodes with 11DQ10's
replaced all the 10uf caps arround the regulators with starget of the same value.
replaced the 1000uf with 1200uf pana fc's and bypassed with wima film caps.
replaced the 47uf coupling caps with 2.2uf pio's
The main sonic gains were from the psu mods.....deep bass and sweater treble. The bass is now so deep that pictures in adjoining rooms now resonate/rattle .... took me a while to find what was playing along !
and it trounced a benchmark dac1 ..... in the dac1 owners opinion! so much so that he is seriously thinking of selling the dac1.
The dac 1 sounded shut in and nasal in comparison to the modded src regardless of the settings on it. In fact the dac1 owner said he thought the src was stunning in standard 44.1kh to 44.1kh .....when upsampled to 96kh all the instraments were give air and space and varrious musical threads could be easily followed.
must try the decoupling cap on the dac chip.
rtd 18th November 2006 09:22 PM
Hi all,
I had a TDA1541 DAC which is faulty Now, So I'm looking from some other DAC solutions (DIY or Tweak).
SRC2496 seems interesting despite of its "old aspect". But I can't find large PCB photos or schematic (hard to get from behringer I read).
So is there anyone who has large board picture ?
It is to verify if it could be possible (mainly space ??? ) to directly take the balanced output from the AKM4393 and add an LPF (bypassing the output stage)
I read elsewhere that the board is only layer ? Am I right too?
thanks
Resources saved on this page: MySQL 18.75%
Copyright ©1999-2017 diyAudio
