Behringer SRC2496 mods
Old 20th January 2013, 06:10 AM   #121
tomfiggy is offline tomfiggy  United States
I have an src2496 I am going to mod. Mine is the one with parts on the underside of the board. I have the schematic from Lampizor. I noticed that the power supply is a good design for getting the required voltages as cheaply as possible. I am building four Jung super regulators. I am going to use two power transformers. I have a dual secondary 2x 15v torroid, and a dual secondary 2x 8v. I will use 4 FWB with fast diode rectifiers, one for each secondary.
I have a 4396 DAC chip to swap. Reading the data sheet AKM says the 4396 is "semi pin compatible" with the AKM4393. Some pins should be connected differently. I will hook it up per the data sheet.
Also have an AKM5396 ADC to swap. I'll take the "sense" wire from the psu and connect it directly to the 5v analog connection on the ADC. Finally I'm replacing the signal op amps with LME43923's
Old 27th February 2013, 11:35 AM   #122
aheborst is offline aheborst
how did it end? and make some pictures
Old 1st March 2013, 08:23 PM   #123
I posted some pics. The regulators are all hooked up now. I was tryiing to use connectors so I won't have to desolder but the connections proved unreliable as the 10ohm remote sense resistor needs to be right at the connector on the wire harness and while testing the supplies one of the resistor lesds broke and with no remote sensing it passed 22Vdc . . . not good. I soldered pins into the Ground and Vout holes of the four exixting 7800 series regs. Then I built up the little boards with the solder terminals and the 10ohm resistors for the remote sense at the input on the board.
I replaced the AK4393 with an AK4396. Very carefully it's a tiny chip. I took the output after the ist OP Amp from the 47uf cap. As you see in the next pic I have four 6.8 uf caps made of 2, 3.3uf and one .22uf Wima MKP10 caps. If the thing works that will be the next mod with a passive output stage.
I just finished working all the bugs out of the regulators and wiring everything together last night. I'm taking a day off before I use the Variac to bring it up and see if it works.
Old 18th March 2013, 02:07 AM   #124
After debugging some issues I have it up and running. The AKM4396 "miracle DAC" is working perfectly. It is super quiet. I replaced the dual Op Amps in the gain stage, and the differential to single ended converter after the DAC with LME49723. I haven't done the direct out through caps mod yet. I'm picking the signal from the first amp after the DAC.
Old 10th May 2013, 05:20 PM   #125
Decoherent is offline Decoherent
Had anyone an idea of how the 8420 is configured in the SRC2496? I would like to try to feed the I2S input with a USB DAC (being this one in master mode) and my impression is that the 8420 there is hard configured for a EAS setup.
Anyone has more info about it?
Thanks.
Old 26th November 2013, 09:33 PM   #126
bmxmen is offline bmxmen
Hi I have src2496, it is upgraded. But im wonderig about decouple the CS8420 on its pins ,what it is doin? in the picture it is a smd cup? 100nf?
Old 17th June 2014, 07:56 PM   #127
SomekPoland is offline SomekPoland  Poland
Hi guys!
I just bought SRC plain new and did XLR to RCA swap. I'm wondering if someone have schematics to the newest(i guess) revision of PCB: yellow parts on the bottom. Even stock it sounds pretty good i admit.
Old 3rd July 2014, 09:18 PM   #128
So, after a while i did some mods to my SRC: caps, swaped one voltage regulator, analog stage is based on Veterans board, simple lpf there. Photos and impressions tomorrow. What is weird: Behringer placed caps(10uF) on one channel output from dac, but not on the other one!!
Old 25th February 2015, 08:18 AM   #129
dimkasta is offline dimkasta  Greece
dimkasta's Avatar
Guys does anyone have the current version? Are the mods and sound quality still applicable?
Too many projects... so little time...
Old 2nd January 2016, 05:51 PM   #130
ravenman is offline ravenman  Slovakia
Hi, im bought used Behringer SRC2496 and i have problem with slight silent noise in analog output at sample rates 48,88,96, in 44,1khz is everything deadly SILENT , is design flaw - feature or my Behringer have a problem ? This noise is generated by behringer on all digi inputs (SPDIF, XLR) in D/A mode .
Behringer SRC2496 modsHide this!Advertise here!
Behringer SRC2496 A/D D/A with THS4032 seeyou Digital Line Level 13 2nd January 2010 03:19 AM
DAC Behringer Ultramatch PRO SRC2496 magnum_1 Swap Meet 4 29th June 2009 03:50 PM
Behringer SRC2496 into DCX2496 giulio Digital Line Level 1 15th December 2006 11:15 AM
WTB: Behringer SRC2496 tf1216 Swap Meet 10 8th March 2006 11:23 AM
Behringer SRC2496 Spearmint Digital Line Level 10 19th September 2004 02:03 AM
