| Digital Line Level DACs, Digital Crossovers, Equalizers, etc. |
My DCX recently seems to be providing different levels on the outs when they are set to the same value differing by as much as 6dB. For example output when 5 and 6 (my left and right tweeter outputs) are set to 0dB, one plays louder.
I've done several tests to eliminate drivers, cables, amps and preamps but how can I test the DCX on the bench and verify with DMM? Has anyone RMA'd their DCX? |
#2 |
UC,
Why are you using 5/6 as your tweeter outputs? I'm using 3/6 as per the default configuration. Using pinknoise for my DEQ I see all paired outputs 1/4, 2/5, 3/6 to have the same relative level when set to 0db. Do you have access to pink noise generator? --Chris |
#3 |
While trying to isolate the problem I switched from the default 1,2,3 / 4,5,6 to 1,3,5 / 2,4,6. This only helped to suggest that the issue pertains to specific output channels and not the DCX configuration.
I can get pink, white, sine, triangle, square, etc. from TrueRTA. If I were to guess I would think I would turn off all filters and crossovers for all channels and set all input and output levels to 0. Then I would input a sine wave at maybe 1k and measure the output by using my DMM on pins 1-2 and then 1-3 which should provide the same value. I'm not really certain how to measure that, VAC on my DMM? Then I'd repeat this for each channel and for a handful of other frequencies. |
#4 |
Why dont you hook up a Mic and let the auto setup function take care of all the annoying stuff
Persistence is better then intelligence. Unless persistence kills you. |
#5 |
DIYNewbie ..... i see you have a DEQ along with your DCX .. does it daisy chain and control the crossover with the serial link ? I want to buy one hook it all up and let it auto level my room THEN play with it ... is that a possibility ? Have you done anything similar ?
#6 | |
I've unbound the channels so I can adjust each one individually and get both speakers measuring the same but I went to a lot trouble to build a fixed attenuator for each channel so I could run with all my levels at 0dB. |
#7 | |
The method I used is as follows : 1) set cross over points for each speaker on DCX 2) check polarity with DCX auto-align function selecting only the "polarity" option. 3) time align drivers with DCX auto-align function selecting only the "short delay" option. 4) run auto EQ function on the DEQ to equalize the room response (be sure not to set below the roll off of the speakers or you'll en up with a really nasty boost on the bottom which degrades the sound. I'm connecting mine Digital into the DEQ, Digital between DEX and DCX which IMHO adds the least amount of noise... Hope This Helps --Chris |
#8 |
The outputs are balanced; are you using them balanced or single ended?
If you are using them single ended, and one channel has the unused output connected to ground, but the other channel has it left floating, then there will be a difference in level. Just a thought, but it's an easy fix if that is your problem
#9 |
I currently have them setup as detailed in this thread: Setting up active speakers...
In an earlier thread I posted the schematic of what I am using: http://www.diyaudio.com/forums/attac...amp=1125518341 It's accurate with the exception that I excluded the toggle switches for level adjustment and polarity selection. |
#10 |
All you need for a source is a signal generator or sinewave test tone from a test CD of some sort. Any frequency will do.
Program your DCX as a direct feedthrough with no processing on all six channels. Use your DMM set to read AC volts and take some readings. Your external output configuration schematic looks fine. It's configured to attenuate 6db on both the + and - outputs and it's not connecting pin 1 to pin 3 (which is good.) All six channels should read exactly the same measuring between pin 2 or 3 to ground (pin 1.) If they don't then you've got some kind of internal hardware problem. Cheers, Davey. |
| DCX2496 update problem | heineb | Digital Line Level | 85 | 3rd April 2013 02:38 PM |
| Problem with Behringer DCX2496 | jan.didden | Digital Line Level | 29 | 27th September 2010 04:04 PM |
| Extremely troubling DCX2496-DEQ2496 interface problem | Vadim | Digital Line Level | 6 | 20th January 2007 06:23 PM |
| DCX2496 front panel problem | jhenderson01075 | Digital Line Level | 0 | 2nd April 2006 09:09 PM |
| DCX2496 upgrade problem | sfdoddsy | Digital Line Level | 9 | 24th May 2004 02:36 AM |
