Behringer DCX 2496 to prototype active crossover
Old 1st September 2005, 08:11 AM   #21
Irakli is offline Irakli  United States
Irakli's Avatar
Hi All
I have a tri-amp system and bought DCX2496 exactly for the purpose to optimize the crossovers.
it is a fantastic unit as far as the functionality is concerned. However, the bad news is that it completely destroys detail in the sound, basically turning high end system to the mid-fi one.
At first I thought that signal level matching was a problem. So I built active six channel volume control (thanks everybody on this forum for help) and placed it after the DCX. Sound improved somewhat, but the lack of detail (or distortion) is still prominent.
The best thing is to use DCX with some CAD software and soundcard. I am using TrueRTA spectrum analizer ($100). My goal is to approximate driver + crossover response to that of the 4th order LR filter.
First, I looped DCX with a soundcard and generated set of 4th order LR curves with different cutoff frequencies. Then I added whole chain in the loop (card out -> DCX -> amp -> speaker -> mic -> mic amp -> card in), turned on pink noise and tried to approximate overall response to one of the pre-generated curves.
It is still a work in progress. The encouriging result is that I can get away with second order filters. This is a big thing because reducing filter sections will diminish cost of the real analog crosover significantly.
To summarize, DCX is a great thing to play with, but I would not use it in a high end system.
Old 1st September 2005, 07:45 PM   #22
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Would you use it under 70Hz just to drive subs and notch out some room nodes in a high end conext?
Old 1st September 2005, 08:03 PM   #23
pinkmouse is offline pinkmouse  Europe
pinkmouse's Avatar
Two words- Gain Structure!
As pro kit needs much greater signal levels to work efficiently, especially with an A-D first stage, you need to boost the input signal level as well.
Rick: Oh Cliff / Sometimes it must be difficult not to feel as if / You really are a cliff / when fascists keep trying to push you over it! / Are they the lemmings / Or are you, Cliff? / Or are you Cliff?
Old 27th October 2005, 06:48 PM   #24
AnthonyPT is offline AnthonyPT  Australia
Send a message via ICQ to AnthonyPT
Hi
that SI 6 channel remote volume Kit at Altronics OZ is being reduced to just AUS150 (US100 approx.) If one can only get the DCX signal strength down and pop in better buffer Ics sure would make a clean solution for controlling volume to six amps needed with the DCX 2496. Looks like the case alone sell for AUD$99 retail. Will go and break out my piggy bank for it. Funny how we do thing backwards.
I still have to get the DCX 2496 itself! I'm still using an analogue
3way active 24db crossover. There I was going on about prototyping with the DCX2496 and then making high quality Analogue boards from the listening data! Maybe a DCX2496 in 2006 or in the OZ group buy?
AnthonyPT
PS URls are on an earlier post on this topic.
Behringer DCX 2496 to prototype active crossoverHide this!Advertise here!
FS: Behringer CX2310 two-way active crossover nl Swap Meet 1 10th June 2009 03:06 PM
FS: Behringer CX2310 active crossover plus 2x PEQ2200 parametric equalizers nl Swap Meet 6 21st May 2009 04:58 PM
Besides Behringer what active crossover to look for fazman Multi-Way 4 18th November 2007 04:24 AM
WTB: Behringer DCX & DEQ 2496 Tristanc1 Swap Meet 2 17th October 2006 06:35 PM
FS : Behringer CX3400 Active 3way crossover Jean Swap Meet 4 12th July 2003 11:28 PM
