diyAudio (
-   Digital Line Level (
-   -   Behringer DCX 2496 attenuation of outputs? (
AndrewT 21st April 2005 09:11 PM
Hi all,
Getting ready to connect my digital xover.
What value of attenuation would be recomended for the outputs?
I will be using amps with 34db to 35db of gain with 90db/w speakers.
A db range to suit quiet and louder music would help.
I want to wire up a temporary attenuator until I have time to develop a digitally controlled analogue attenuator as suggestted in the thread that ran recently.
DougL 21st April 2005 10:12 PM
I am using 6 dB attenuation, simply by NOT shorting the - to ground on the Unbalanced output.
I would start there.
bzdang 22nd April 2005 03:55 AM
2 Attachment(s)
Here's the beginnings of a simple attenuator box with a stereo pot from Percy Audio and some ratshack parts.
AndrewT 22nd April 2005 06:57 AM
The manual talks about automatic detection of unbalanced connections and adjusting gain to compensate. Have I reworded that correctly?
I intend connecting both hot & cold to a 10k for each, then connecting a dropping resistor (about 1k0 to 1k5) between the 2 10k's. That way it appears to be balanced, then tap off across the 1k0 as input to the power amp.
If output is +22dbu at clip then -6db still leaves +16dbu (almost 5v) at the input to the power amps. see my other thread re output voltage.
Davey 22nd April 2005 05:23 PM
Yes, you reworded correctly. That's exactly the way it works.
Your balanced attenuator configuration sounds good. The component values you mentioned would yield a little over 20db of attenuation which sounds about right with your high gain amplifiers. However, you may need to fine tune the values so the DCX doesn't clip. I would try maybe a 5k potentiometer in place of your 1-1.5k parallel resistor and experiment to find the optimum setting and then replace with a fixed resistor.
I am assuming your power amps have balanced inputs?
Resources saved on this page: MySQL 18.75%
