| Digital Line Level DACs, Digital Crossovers, Equalizers, etc. |
#11 |
The schematics:
The middle one is the passive filter, with the balanced resistor values lumped to one side to avoid differential probing. The lower one is the input circuitry of the DCX; this is interesting, since it has a kind of pre-emphasis; it has a high pass characteristic. Curves to follow. Jan Didden
It is a capital mistake to theorise before one has data. Insensibly one begins to twist facts to suit theories, instead of theories to suit facts - Sherlock Holmes Check out Linear Audio Vol 5! |
#12 |
Input pre-emphasis (analog inputs):
Far from level... Jan Didden
#13 |
Jan, If I understand you correctly, you are saying that the DCX has a sort of preemphasis filter for analog inputs. So how does it deal with the digital input? Do you suppose that there is a similar preemphasis in the digital domain? And what would be the point of this preemphasis? It would be interesting to actually probe the unit and measure it's input circuitry prior to the A/D converter.
Regards, Ron |
#14 |
Ron,
My simulation doesn't show nearly as much "pre-emphasis" as Jan's, but maybe I've got something setup wrong. I'm seeing an approximate 0.9 db shelving action created by the filter. I think the difference is explained by what the load is seen by the circuit. Jan assumed zero ohms because of the two capacitors shunting the voltage divider on the + side of the inverting amplifier. Anyway, I've looked at the outputs with both digital and analog inputs and they look flat to me. Any frequency contouring that's going on in the analog sections must compensated for in the digital domain somewhere. Cheers, Davey. |
#15 |
So it's pretty much a non issue. Thanks Davey.
Cheers, Ron |
| Behringer DCX2496 | 12 Cents | Swap Meet | 0 | 29th July 2007 08:27 AM |
| Behringer DCX2496 | RAAMaudio | Swap Meet | 0 | 19th February 2006 07:15 PM |
| Behringer DCX2496 questions | noah katz | Digital Line Level | 18 | 23rd October 2005 07:49 PM |
| Behringer DCX2496 questions | noah katz | Digital Line Level | 4 | 21st October 2005 05:43 AM |
| Behringer DCX2496 12v ps | Flyingeyepro | Car Audio | 0 | 30th July 2004 08:05 PM |
