PCM2707, I2S out
PCM2707, I2S out
Old 23rd October 2004, 07:08 PM   #21
josiphal is offline josiphal  Croatia
To erozsolt:
PCM2707 format is I2S, but AD1865 work with 18-bit MSB first (not I2S).
For conversion from 20-bit I2S to 18-bit MSB first, look here.
Any conversion from 16-bit to >16-bit is not easy.
To 000940:
Try TDA1543 first.
Josip
Old 23rd October 2004, 07:27 PM   #22
00940 is offline 00940  Belgium
00940's Avatar
Josip : have you tried both ?
Old 24th October 2004, 04:04 PM   #23
Hi 00940,
I have TDA1543A connected to CD-ROM LRCK/BCK/DATA lines.
TDA1543 is simple and cheap solution.
Maybe PCM1794 is better? I didn't try it.
My future project is PC2707 & TDA1543...
Josip
Old 13th May 2006, 10:04 AM   #24
err_smart is offline err_smart  Moldova
Can anybody tell me about PCM2707 I2S out jitter value?
Old 13th May 2006, 10:35 AM   #25
dddac is offline dddac  Germany
DDDAC Audio
PCM2707, I2S out
I have implemented the 2707 as USB to I2S converter and although I have read some comments, that there will be no improvement, taking a XO clock (tried it or just thinking ?), there is for sure an improvement ! No day and night, but for the money you spend on a XO clock (29 Euro) a very good tweak, worth it....
You can use the 2707 as dac it self, but it is not "high end". ranges like an average CD player, which is better than most sound cards of course. All is relative ... But with the I2S at hand, you could feed any DAC with I2S input (like I like the TDA1543) If you need a master clock signal, indeed, than you have a draw back... The only thing comes to mind, is using another free running clock again and do aysnchrone reclocking....
any way, below is the circuit, so you can have a look how I implemented the 2707.... (page 8 of pdf doc)
Link to Circuits PDF
doede
www.dddac.com
Happy listening and building
Old 13th May 2006, 11:56 AM   #26
00940's Avatar
There studies of the pcm2707 jitter here : http://www.diyhifi.org/forums/viewto...ighlight=#8368
All that is excessive is insignificant. Talleyrand
Old 24th June 2009, 02:39 PM   #27
mravlcax is offline mravlcax  Slovenia
Default Hello
I know this is old theme but I need some help. I made pcb after this scheme, which is posted. I connected i2s outputs to the TDA1543 but its not working. Can someone verify if my scheme is correct. The PCM2707 is supplied from USB.
Regard Aleš
Old 25th June 2009, 07:53 PM   #28
Haven't see that I didn't post the file.
Regards Aleš
PCM2707, I2S outHide this!Advertise here!
FS:USB DAC with PCM2707+AD1955 bbp Swap Meet 4 19th September 2007 12:38 PM
Pcm2707 Usb->i2s Rocky Digital Source 0 21st October 2005 01:35 AM
which USB to I2S cct for PCM2707? sceglar Digital Source 0 29th August 2005 01:23 PM
PCM2707 USB-->I2S how to use etc. nl Digital Source 4 5th August 2005 12:29 PM
