| Digital Line Level DACs, Digital Crossovers, Equalizers, etc. |
Hi all
I made SPDIF transmitter board for DCX2496. It is easy and you can get 3Way digital X-over device at very cheep price. (1) The signal you need from AK4393, get these signal with very slender cable, solder with microscope or something. Pin 3:MCLK?APin 5:BICK?APin 7:LRCK These signals are common for all AK4393. Pin 6:SDATA , on the side of AK4393, you can find 10ohm R, you can get 3 SDATAs from this register's solder easily. (2)CS8404 configure PRO=Low, TRNP=Low, M2M1M0=100, I2S mode. Pullup RST with 10kohm. (3)CS8404 connection ?@MCLK->MCK, BICK->SCK, LRCK->FSYNC, SDATA->SDATA (4)SPDIF output is done by TOTX173 (5)5V power is made by 7505, on each CS8404, 9V is supplied from Pin 1 of 7805 on the main PCB. GND is supplied from Capaciter's solder. (maybe direct from power module is better) Then now you can get 3 SPDIF signal, for DCX2496's ch12, 34, 56. Do not forget to make DCX2496's configuration to LL-MM-HH.?@ Now I'm using this for connection to 3 units Panasonic SA-XR50(maybe same as SA-XR45 or so). Tanto |
#2 |
This has always struck me as an 'obvious' mod for the dcx, and the panasonic units are a perfect match as they will all track volume control from a single remote.
Good job. Any chance you can post pictures? |
#3 |
Nice one
![]() Petter |
#4 |
よかったですね。写真を見せてもらいたいんです。
#5 |
These are SR50s, it receives 24bit/96kHz.
#6 | |
#7 |
Total Image from Upside of board.
you don't need switch, just connect M2M1M0 = '100' |
#8 |
downside of board.
sorry for non schematic and dirty work |
#9 |
Must have been in moderation. Especially confusing with the new click-to-see model.
I really like the super-thin adaptors...that has to be good from a parastic inductance perspective. I've never seen these sold before... Tanto, have you done this kind of thing before with solid-core wire? I have experienced reliability problems in the past, the wire is too stiff and tends to pull off the SMD pads at some indeterminate point in the future. Frustrating. I use small-gauge stranded now. |
#10 |
I'm sorry , I attached photo on post4,6,7
but it is not shown on thread ??
| Behringer DCX2496 digital X-over | byteboy | Digital Line Level | 3293 | 25th May 2012 12:59 PM |
| DCX2496 mod for Digital OUT. HELP | KY | Digital Line Level | 2 | 3rd March 2005 03:49 PM |
| Page generated in 0.10257 seconds (80.86% PHP - 19.14% MySQL) with 11 queries |
