Go Back   Home > Forums > Source & Line > Digital Line Level
Old 12th December 2011, 10:53 AM   #331
tvicol is offline tvicol  Romania
tvicol's Avatar
Send a message via Yahoo to tvicol Send a message via Skype™ to tvicol
Originally Posted by AndrewGM View Post
So, what is the best op amp for i/v conversion ?
LME49713
Tibi
Old 12th December 2011, 01:34 PM   #332
tiefbassuebertr's Avatar
Originally Posted by tvicol View Post
LME49713
Tibi
thank you - good advice.
ESS Sabre Reference DAC (8-channel) (post #1315)
LME49713, could be a killer opamp
http://audio.com.pl/testy/cary-audio...-xciter-dac:25
http://audio.com.pl/pdf/testy/przetw...ITER%20DAC.pdf
http://www.elforum.ro/viewtopic.php?...59477&start=15
Who can say the lowest possible supply voltage without loss in audible quality for +/- 2Vss output swing (the mentioned value of +/-5V from datasheet is probably too low)?
Where are to find the internal simplified schematic diagram?
Old 12th December 2011, 01:47 PM   #333
dirkwright's Avatar
LME49713
Tibi
Keeping RFI out of that chip is going to be a challenge for anyone.
Old 12th December 2011, 02:14 PM   #334
theAnonymous1's Avatar
I built a headphone amp using two of these that was powered by a DC/DC converter. No RFI problem that I could tell; excellent sound.
"If you don't like funerals don't kick sand in Ninja's face." - Ninja
Old 15th December 2011, 11:07 PM   #335
Gosh, already TI set up the National website datasheets on their own domain...
http://www.ti.com/lit/ds/symlink/lme49713.pdf
http://www.ti.com/lit/ds/symlink/lme49710.pdf
http://www.ti.com/lit/ds/symlink/lm4562.pdf
Good bye Nat Semi!
Old 16th December 2011, 11:07 AM   #336
LME49713
Tibi
1. inverting input of the current feedback OP is a poor choice for virtual ground summing
and
2. transimpedance current feedback OP cannot have a cap across the feedback resistor
Datasheet specifies the Rf value of 1.2Kohm to be optimal; this value could give less than desired voltage output level with well-regarded current-out DAC's that have only around 1mA output…. which means a second gain stage…. or…..the choice of a sub-optimal DAC (with higher Iout)… or even worse – the Vout DAC
There are OP's that can give outstanding results if used as I/V, due to very high slew rates, extremely low input bias current and very low offset voltage + they are voltage feedback OP's. The only thing to pay attention to is output oscillations, but once done right – this combination can really show what preceding current-out DAC is capable of. If the oscillations are not controlled properly the end result could be quite bad.
49713 will most definitely sound very nice (at least the oscillations would be easier to control compared to a fast voltage feedback OP) - however, the PCB trace cutting (cap should be placed at the input of the current feedback OP, in combination with the resistor for the desired cut-off frequenc, and damping) and a bit of adjustments are needed to allow this chip to be used in place of voltage feedback OP. Not many DIY-ers are ready to do this... many expect drop-in replacement should just work irrelevant of the type of the OP at hand.
Boky
Old 16th December 2011, 11:16 AM   #337
qusp is offline qusp  Australia
Sometimes a square peg fits a round hole just fine
qusp's Avatar
is this series RC at the input of the CFB chip considered part of the dac output, or the opa input? ie. i take it you must know the CFB chips inputZ to enable proper choice for the size/value of the component? or does the resulting LPF rely mainly on the dac's output impedance? i expect its a combination of the 2, but which has the more profound effect? i'm on mac so cant run spice unfortunately
Single supply opamp - unequal rail voltage and opamp selection Hans L Parts 8 19th February 2006 02:15 PM
RCA conversion oogared Instruments and Amps 1 1st September 2005 09:31 PM
Regulate the psu of a power opamp with a similar power opamp? Franz G Chip Amps 34 19th October 2004 10:49 AM
D1.I/V conversion nar Pass Labs 2 20th April 2002 10:46 AM
Page generated in 0.11800 seconds (78.61% PHP - 21.39% MySQL) with 11 queries
