| Digital Line Level DACs, Digital Crossovers, Equalizers, etc. |
#21 | |
Banned
Found it! Its a Sziklai input folded cascode design. Or two times common base. It is drawn somewhat awkward due to that stupid schematic capture program or my computer blindness. |
#22 | ||
The rest of this circuit is zero feedback, which is something of a double-edged sword. This makes things much more transparent, but also much more revealing of the actual implementation. In other words, if you use (for example) a bad sounding capacitor with a feedback circuit, the coloration produced by the feedback tends to mask the problems of the capacitor. But in a zero feedback circuit, you will much more clearly what the capacitor is doing to the signal. |
#23 |
Banned
Elso:
Your implementation of the CFP is not quite right...... You have to be very careful to keep it from oscillating. Lower the gain some.......for starters. As for transparency: Yes, it must have a clean supply. And guess what......Charlie and I tend to use open loop supplies. Or something similar....that has constant Z vs frequency. I am firmly convinced that a large part of my sucess is a result of the total implementaion, not just coming up with a common-base, or common-source circuit. Jocko |
#24 | |
Banned
It was just a proposal. I haver never built this one. I built something simpler from Rudolf or Thijs for real life testing. Will try to find it back. I know you are using open loop supplies.
#25 | |
I ran it through LTSpice and it confirms this, here is the netlist: I1 in 0 SINE(0 1.2m 5Meg) AC 1.2m X§U1 0 in N002 N001 out 1pole Avol=3k GBW=40Meg Slew=125Meg ilimit=25m rail=0 Vos=0 en=0 enk=0 in=0 ink=0 V2 N002 0 15 V3 0 N001 15 R2 out in 1.66k R3 0 out 10k C1 out in 2000p .tran 2m ;ac oct 10 100 100Meg .lib 1pole.sub .backanno .end Can you tell it is a slow day at work
#26 |
I couldn't resist some plots...
Top: OPA627: Avol=10Meg GBW=16Meg Slew=55Meg Bottom: AD825: Avol=4k GBW=40Meg Slew=125Meg V(in) is inverting input, V(out) is output of opamp. Zf is 1.66kohm || 2nF. Notice how, in the audio-band, the inverting input is 180 degrees out of phase with the current when using AD825 while it is 90 degrees out of phase when using OPA627. My gut feeling tells me this difference affects the DAC performance in some way. Inverting input voltage @5MHz is ~-50dBV = 3mV. |
#27 |
Ojg,
Just checked this with MicroCap. Model provided by ADI says at 5MHz the inverting input (closed loop; output impedance of the DAC set to 2k and I/V resistor is 1k - doubled value of the I/V resistor will double the inverting input’s impedance) has impedance of about 150 Ohm. Both AC and transient analysis show this. Since the open loop response of the model looks a bit shorter (11MHz) than shown in the datasheet (25MHz), and the phase shifts earlier, I would expect lower value in reality, maybe about half this value, but not less than that. Btw, you are misquoting Socrates. Pedja |
#28 | |
I tried the Sowter transformer recommended by Doede Douma and didn't like the sound at all! Distortion was also barely -78dB at 1 kHz. The opamp route sounded better. |
#29 | |
Here's looking at you, kid. |
#30 | |
That is, making the inverting input high impedance and the non-inverting one low-impedance, which of course you cannot do with a chip unless you design it. Edit: Hm, maybe not if you use it in invertin config?? Guess it is to late to think about it now. |
| Single supply opamp - unequal rail voltage and opamp selection | Hans L | Parts | 8 | 19th February 2006 03:15 PM |
| RCA conversion | oogared | Instruments and Amps | 1 | 1st September 2005 10:31 PM |
| Regulate the psu of a power opamp with a similar power opamp? | Franz G | Chip Amps | 34 | 19th October 2004 11:49 AM |
| D1.I/V conversion | nar | Pass Labs | 2 | 20th April 2002 11:46 AM |
| Page generated in 0.13822 seconds (82.01% PHP - 17.99% MySQL) with 11 queries |
