| Digital Line Level DACs, Digital Crossovers, Equalizers, etc. |
#251 |
One Seriously Addicted to Audio and Electronics
That is the uncompensated GBW. The more you compensate, the smaller GBW will be. GBW can therefore not be 60MHz compensated.
It will be about 10MHz with 22pF compensation and 100pF load. See datasheet. 100pF is not an unpractical value if you load the opamp with a filter stage or interconnect at the output. Regards, Ray |
#252 | |||
5534 from TI is de fakto unity gain stable (TI has another layout), 5534 from others(NJM,TDA,SSM) will oscillate with unity gain&small output capacitor Quote:
my regards, Nazar
"In developing audio devices we can always find creative non standart solutions that will ensure the best sound" (с) www.overture.org.ua |
#253 |
RC input compensation still reduces the effective practical bandwidth that we can use, that's the point of compensation, right?
Ray |
#254 |
RC input compensation do not reduce gain, slew...
#255 | |
...is I disappear. There is ONLY the music. Last edited by Bassivus; 12th October 2009 at 09:58 PM. |
#256 | |
except as a proxy for increased linear input range - but why not 1st design the circuit for low input V error? DAC I/V for reproducing audio doesn't need to move the output faster than the filtered audio frequency output signal's rate there's no need to reproduce the step/switching glitches - they should be flitered out as early as possible high current/low open loop Z output stage would be a better way of soaking up the glitches thru the feedback C |
#257 | |
Ray |
#258 | |
Use of video opamp in I/U is fight with the consequence rather than cause regards, Nazar
#259 |
I plea for a gentle 1st order passive filter before the signal enters the opamp.
Ray |
#260 |
Are there new experiences?
In the meantime was launched various new OP-AMP IC's from TI/Burr Brown, Analog Devices and National Semiconductor. |
| Single supply opamp - unequal rail voltage and opamp selection | Hans L | Parts | 8 | 19th February 2006 03:15 PM |
| RCA conversion | oogared | Instruments and Amps | 1 | 1st September 2005 10:31 PM |
| Regulate the psu of a power opamp with a similar power opamp? | Franz G | Chip Amps | 34 | 19th October 2004 11:49 AM |
| D1.I/V conversion | nar | Pass Labs | 2 | 20th April 2002 11:46 AM |
| Page generated in 0.11952 seconds (78.10% PHP - 21.90% MySQL) with 12 queries |
